rudder balance
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
pinkston(at)carolina.rr.c
PostPosted: Sun Jul 08, 2007 5:52 pm    Post subject: rudder balance Reply with quote
Need info >>>>>the book said add 4.5 lbs to rudder for counter weight but I don”t see if that is all you add if it’s not balance or is that just enough to keep flutter out ,,,,,,,, also how about using stainless steel for the fire wall,,,I understand it is a little more weight but seems better then the fire proof stuff and the stock fire wall that is made out of aluminum ……..randy Pinkston super 2 rg also rv7a,,,,, 705rp,,,,, flying,,,,, 350+ hrs
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
