Michel
Posted: Fri Jul 06, 2007 9:41 am Post subject: [OFF-TOPIC] Jack L Bell |
Jack, I tried twice to answer your direct email but it bounced back.
Sorry.
My answer was: No, my Jabiru engine has the serial nr. 1665 and
therefore not an old one and if the prop sounds short in diameter,
remember that it is a straight cut tip and not a rounded tip like the
Sensinich. You can't just compare diameter across manufacturers.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
