knowvne(at)aol.com Guest
Posted: Tue Jul 03, 2007 7:28 am Post subject: Federal Funding |
How does some one determine if a field has received or is receiving
federal funding ?
Is there a list of fields some place for the public to review??
 Mark
rlaird
Posted: Tue Jul 03, 2007 7:55 am Post subject: Federal Funding |
By default, any airport designated as public is required to allow any
aircraft to use it's services. This includes ultralights. (If a
private airport, designated for public use, has never taken federal or
state funding, then they have the right to deny services, but how will
you know until you land there?) If a public airport owner can make a
case to the FAA to disallow certain aircraft for particular reasons,
then portions of or all services can be denied. That information, as
far as I understand it, is supposed to be published in the AFD
(Airport/Facility Directory) for public use airports, so, if you're
at all concerned, then refer to the AFD for the airport you're
interested in.
-- Robert
federal funding ?
Mark
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Tue Jul 03, 2007 8:50 am Post subject: Federal Funding |
Interesting...
I would have never guess the AFD would have listed such info... I'll
take a look...
 Mark Vaughn
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Tue Jul 03, 2007 9:31 am Post subject: Re: Federal Funding |
"By default, any airport designated as public is required to allow any
aircraft to use it's services. This includes ultralights."
These rules were written before Sport Pilot and the FAA has ignored overweight ultralights for many years. Everyone knows that an ultralight is a single seat no more than 254 lbs empty weight, flies no faster than 63mph, and has a 5-gallon fuel capacity.
Under the new rules, any aircraft (air vehicle) that doesn't meet this standard should be registered with the FAA. This means all overweight fixed-wings, trikes, and PPC's.
After the deadline, the FAA will be able to keep overweight unregistered ultralights out of airports. Already we are seeing signs going up at our airports stating this.
If your machine is overweight and not registered after the deadline, your flights may be limited to private fields only.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
rlaird
Posted: Tue Jul 03, 2007 9:51 am Post subject: Federal Funding |
I'm sure you're right, Ralph. My statement would be more accurate to
have said: "...any airport designated as public is required to allow
any FAA recognized aircraft to use it's services. This includes a
valid FAR 103 ultralight."
BTW, take a picture of one of those new signs and send it to me... I'm
really curious!
-- Robert
On 7/3/07, Ralph B <ul15rhb(at)juno.com> wrote:
Ralph
Ralph B
Original Firestar
20 years flying it
http://forums.matronics.com/viewtopic.php?p=122020#122020
Robert Laird
Houston, TX area
rlaird
Posted: Tue Jul 03, 2007 9:58 am Post subject: Federal Funding |
Mark --
Below is a snapshot of a A/FD entry for an airport just south of me... note the "no touch and go nighttime lngs"... that's a restriction that either they asked the FAA for, or the FAA told them they had to abide by. I've seen other A/FD entries for "No ultralight activities" but can't put my finger on one right now.
As I mentioned, if an airport owner can make a good case, the FAA will add the restriction. Sometimes, the FAA sees an issue (like a noise sensitive area) and will compel the airport to comply and will publish it in the A/FD, as shown in this excerpt.
[img]cid:part1.05060408.04050107(at)cavediver.com[/img]
43.43 KB |
447 Time(s) |
Robert Laird
Houston, TX area
Ralph B
Posted: Tue Jul 03, 2007 4:35 pm Post subject: Re: Federal Funding |
really curious!
-- Robert
Robert, here's your picture of the warning sign at the Red Wing airport.
Here is what it says as it's hard to read with the way the camera took it on the inside of the glass:
WARNING
Any aircraft operating at the Red Wing Regional Airport not displaying a registration number nor meeting the definition of an ultralight vehicle
will be reported to the Federal Aviation Administration for enforcement action. An ultralight vehicle is defined as a vehicle that:
Is used or intended to be used for manned operation in the air by a single occupant
Is used or intended to be used for recreation or sport purposes only
Does not have any U.S. or foreign airworthiness certificate, and:
If unpowered, weighs less than 155 pounds, or if powered, weighs less than 254 pounds empty weight, excluding floats and safety devices which are intended for deployment in a potentially catastrophic situation.
Has a fuel capacity not exceeding 5 U.S. gallons.
Is not capable of more than 55 knots calibrated airspeed at full power in level flight, and:
Has a power-off stall speed which does not exceed 24 knots calibrated airspeed.
If your ultralight does not meet the above definition, it must be operated in accordance with applicable aircraft regulations. You will be subject to enforcement actions ($1000 civil penalty for each violation) for each operation of this aircraft.
Tom Blue, Caretaker
Ralph B
44.14 KB |
460 Time(s) |
Ed in JXN
Posted: Tue Jul 03, 2007 5:03 pm Post subject: Federal Funding |
This "caretaker" sounds fascist IMHO. This is what happens when folks don't
speak out.
The vast majority of airports are UL-friendly, or at least tolerant. I
operate out of PTK (Pontiac, MI, tower-controlled) in GA aircraft, and there
are several ultralights based there. The UL guys go out of their way to
comply, some even use radios!
Ed in JXN
MkII/503
rlaird
Posted: Tue Jul 03, 2007 5:42 pm Post subject: Federal Funding |
Interesting (if not a little disgusting)... but how, I wonder, does he
magically discern the weight of a single-seat UL, not to mention the
speed, etc...? And, does he not honor the FAA exemption for UL
trainers? There's no mention of that!
I'll bet his mistress is named Eva and he wears brown shirts, eh?
-- Robert
really curious!
-- Robert
WARNING
Tom Blue, Caretaker
Ralph B
http://forums.matronics.com/viewtopic.php?p=122083#122083
http://forums.matronics.com//files/airport_warning_sign_148.jpg
Robert Laird
Houston, TX area
jindoguy(at)gmail.com Guest
Posted: Tue Jul 03, 2007 6:48 pm Post subject: Federal Funding |
Robert, There is no such thing as an unlicensed ultralight trainer after Jan 31, 2008. After that you have to find a Sport Pilot CFI and a certificated LSA. If it's in the aircraft's operating limitations, an E-LSA can be used for training until Jan 31, 2010. After that it will be only S-LSA that can be used for training.
Rick
On 7/3/07, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote:[quote] --> Kolb-List message posted by: "Robert Laird" <rlaird(at)cavediver.com (rlaird(at)cavediver.com)>
-- Robert
On 7/3/07, Ralph B <ul15rhb(at)juno.com (ul15rhb(at)juno.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Ralph B" <ul15rhb(at)juno.com (ul15rhb(at)juno.com)>
really curious!
-- Robert
WARNING
Tom Blue, Caretaker
Ralph B
"Ya'll drop on in"
takes on a whole new meaning
DAquaNut(at)aol.com Guest
Posted: Tue Jul 03, 2007 7:43 pm Post subject: Federal Funding |
In a message dated 7/3/2007 12:32:52 PM Central Standard Time, ul15rhb(at)juno.com writes:
| Quote: | After the deadline, the FAA will be able to keep overweight unregistered ultralights out of airports. Already we are seeing signs going up at our airports stating this.
Ralph |
Ralph,
An aircraft that weighs more than 254 with a single seat is not an overweight ultralight. It is an illegal aircraft , if you dont have a license to fly and must be registered. On the other hand if the craft meets ALL requirements for an ultralight then it should be legal as a true ultralight today or after the deadline. The FAA has had the authority ,all along, to keep ( overweight unregistered ultralights) from flying anywhere in the USA . It is my understanding that FAR 103 will not change at all. I see " SPORT PILOT" as the solution to force everyone to comply with the rules that have been in place all along. Do the signs you are refering to address Legal Ultralights? My original comment was pertaining to Legal Ultralights.
Ed Diebel
See what's free at http://www.aol.com. [quote][b]
rlaird
Posted: Tue Jul 03, 2007 9:33 pm Post subject: Federal Funding |
Yup, well aware of that, but the sign exists now, so, I was just
wondering why the "caretaker" wasn't taking care of -current- UL
trainers.
On 7/3/07, Richard Girard <jindoguy(at)gmail.com> wrote:
| Quote: | Robert, There is no such thing as an unlicensed ultralight trainer after Jan
Rick
> -- Robert
> > really curious!
> > -- Robert
> > WARNING
single occupant
airspeed.
> > Tom Blue, Caretaker
> > Ralph B
> > Read this topic online here:
> "Ya'll drop on in"
> when you live at the airport.
Robert Laird
Houston, TX area
planecrazzzy Guest
Posted: Wed Jul 04, 2007 5:16 am Post subject: Re: Federal Funding |
Something that wasn't mentioned about Red Wing Airport....
There are 3M "Jets" that Fly out of there.....I SURE that has something
to do with not wanting UL's buzzing around....
I'm sure there has been "Situations"
I'm flying there Thursday morning to get my Transponder Cert.
$75 for the Transponder & $75 for the Alt Encoder (cheapest I've Found)
Gotta Fly...
Mike & "Jaz" in MN - FSII / N381PM
JetPilot
Posted: Wed Jul 04, 2007 10:54 am Post subject: Re: Federal Funding |
| planecrazzzy wrote: |
Gotta Fly...
Where did you find a transponder for 75 bucks ?
Mike
Kolb MK-III Xtra, 912-S |
planecrazzzy Guest
Posted: Thu Jul 05, 2007 2:29 am Post subject: Re: Federal Funding |
If you read it again....I'm getting it Certified....
So , for $150 bucks....I'm buying a Piece of Paper......
Now, if you've got $1,500....You can Buy a "NEW" :
Narco AT 155 Transponder w/AR850 Altitude Reporter
Gotta Fly...
Mike & "Jaz" in MN
| JetPilot wrote: | | planecrazzzy wrote: |
Gotta Fly...
Mike |
59.11 KB |
444 Time(s) |
d-m-hague(at)comcast.net Guest
Posted: Thu Jul 05, 2007 1:34 pm Post subject: Federal Funding |
At 11:55 AM 7/3/2007, Robert Laird wrote:
state funding, then they have the right to deny services...
That's where the issue may arise. Many airports are "privately owned for
public use", and if these have received no federal funding they can deny
landing to anybody, not just ultralights. The airport I used to call home
(N04, now sadly closed) was such an airport. It was ultralight friendly,
actually friendly to any aircraft that could deal with its 1800' strip, but
required prior permission (which was always granted) from ALL transient
aircraft.
Many small airports were originally WWII training or auxiliary
fields. That qualifies as "receiving federal funding" even if the original
acquisition was the only dealing with the feds.
-Dana
The only correct outcome to an armed robbery attempt is a dead armed robber.
