phil.merlin(at)skynet.be Guest
Posted: Sun Jul 01, 2007 1:42 am Post subject: Strobe lights temperature |
Hello,
I have tested my Whelen strobe lights on the bench before installing them, and one of them (the tail one) is overheating (95°C !! after a couple of minutes), although working fine. But it smells like a hot electric device. I cannot get from Whelen whether it is normal or not...
I'd like to have the opinion of other users to compare with...
Thanks in advance,
Philippe
Brussels - Belgium
nuckollsr(at)cox.net Guest
Posted: Wed Jul 04, 2007 7:30 am Post subject: Strobe lights temperature |
At 11:39 AM 7/1/2007 +0200, you wrote:
| Quote: | Hello,
Thanks in advance,
Philippe
Brussels - Belgium
This is pretty toasty but perhaps not out of line for
a devices that is not mounted to an airframe for heat
sinking and cooled by slipstream.
I take it that you've got all fixtures running and there
is a marked difference in temperatures between the tail
fixture and the tip fixtures? Is there a nav-light in
the fixture. Is it on too?
The last time I looked inside one of these there were
two bulbs (nav and strobe) and a pulse transformer to
trigger the tube. Energies dissipated in the fixture
were dominated by the nav bulb and followed by the strobe
tube. The transformer should run stone cold. If you're
smelling something, it has to be the insulation in bulb
sockets, potting compounds or perhaps the insulation of
the pulse transformer. I'm having trouble getting my head
wrapped around the idea that one fixture should be markedly
different than the other two and why it might be different.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
Posted: Wed Jul 04, 2007 8:46 am Post subject: Strobe lights temperature |
Hello Bob,
Thanks for the reply. This t° is reached with both bulbs strobe+position on,
but with the strobe only, it isn't much cooler. I have compared with the
wingtip strobes, and those remain cool enough to take them in hand. I'm
surprised by the difference...
Philippe
-----Message d'origine-----
De : owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] De la part de Robert
L. Nuckolls, III
Envoyé : mercredi 4 juillet 2007 18:28
À : aeroelectric-list(at)matronics.com
Objet : Re: Strobe lights temperature
--> <nuckollsr(at)cox.net>
| Quote: | Hello,
electric device.
| Quote: | I cannot get from Whelen whether it is normal or not...
Thanks in advance,
Philippe
Brussels - Belgium
wgill10(at)comcast.net Guest
Posted: Wed Jul 04, 2007 9:23 am Post subject: Strobe lights temperature |
I believe the energy supplied for the tail strobe is twice that supplied
to EACH wingtip strobe IF the wingtip strobes flash simultaneously...a
wiring option for the installer.
Bill
seipel(at)seznam.cz Guest
Posted: Wed Jul 04, 2007 10:36 am Post subject: Strobe lights temperature |
I have the same problem, and asked the same question on the RV List and
several others reported the same situation. In my case, the tail strobe
flashes twice as many times as the wingtip strobes, which is what I
believe is causing the heating. In my case, it got so hot that it
clouded the lens. I spoke to Whelen about it, and all they could tell
me was that it needs to be installed in the plane and with some length
of wiring between the strobe and power supply. According to the guy I
spoke to, hooking the strobes direct to the power supply with a short
length of wire is bad.
I'm still concerned that it may scorch the fiberglass rudder tip, but I
guess I won't know until I install it.
PJ Seipel
RV-10 #40032
Robert L. Nuckolls wrote:
> Hello,
> Thanks in advance,
> Philippe
> Brussels - Belgium
