ifly4fun2(at)sbcglobal.ne Guest
Posted: Sun Jul 01, 2007 8:00 am Post subject: Primer adhesion |
Hi All,
Yesterday I finished priming my 701 rudder skeleton with PTI Zinc Oxide and I've experienced poor adhesion results. I need some advise on where to go from here.
The only spray painting I've ever been exposed to is the type that comes out of a spray can. I used an HVLP sprayer with the reducer proportions as advised by PTI. The conditions in the shop was 70 deg with 72% humidity. The primer is suppose dry tack free in 5 minutes and it did but the fully cured in 30 minutes hasn't quite happened yet. I've allowed it to cure overnight and the surface can be chipped down to the chem-film with a fingernail. Any ideas what may have caused this and what I should do now?
AJ
naumuk(at)alltel.net Guest
Posted: Sun Jul 01, 2007 8:08 am Post subject: Primer adhesion |
72% humidity might have something to do with it. Try a dehumidifier in your shop.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
Posted: Sun Jul 01, 2007 9:28 am Post subject: Primer adhesion |
Are you scuffing the surface or chemical etching at all? I like Alumiprep. Also I am using Zinc Oxide in the rattle cans instead of Chromate. Think it is a little safer. Adhesion seems pretty good to me, and I live in Nashville, Tn. High humidity is just a fact of life here in summer.
Kevin Bonds
Nashville TN
601XL Plans building.
http://home.comcast.net/~kevinbonds
do not archive DO NOT ARCHIVE
_________________ KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
http://home.comcast.net/~kevinbonds |
Kevin Bonds
Posted: Sun Jul 01, 2007 9:39 am Post subject: Primer adhesion |
Also, a thin coating will adhere better than a thick one.
Kevin Bonds
Nashville TN
Nashville, TN
stol701(at)yahoo.com Guest
Posted: Sun Jul 01, 2007 2:22 pm Post subject: Primer adhesion |
I just zinc chromated the skelaton from my 701 rudder and I live in the very dry Southern New Mexico. We do not measure humidity because we have none (joke). I too can scratch off the primer with my finger nail. Prior to spraying I cleaned up the metal with laquer thinner.
see at: http://websites.expercraft.com/rhansen/
Rob Hansen
dredmoody(at)cox.net Guest
Posted: Sun Jul 01, 2007 3:05 pm Post subject: Primer adhesion |
I'm not a paint expert..... in fact, I hate painting, but I think your problem is that you expected the primer to get hard much too fast. I have found that using self etching Zinc Oxide from rattle cans, cleaning the aluminum with laquer thinner (repeatedly until clean and fairly streak free) then following the directions works well. The primer can be scatched off pretty easily until it has had a few days to harden. Gradually it takes much more than a fingernail to get through it. You can etch before priming..... you can scratch the hell out of the parts with scotchbrite, emery cloth, a rock from the nearby streambed, whatever. But until the primer itself is tough, it can be pulled off the surface. Try giving it more time if you can.
Dred
dbortol
Posted: Sun Jul 01, 2007 3:35 pm Post subject: Primer adhesion |
I'm no expert on this, but it sounds like a surface preparation problem to me. I just zinc chromated the inside of my rudder trim tab yesterday. I scuffed the surface with a Scotchbrite pad, washed it with warm water and lemon-scented dish soap, and rinsed it with hot water. Didn't use any solvents. Let it air dry and brushed the chromate on with a disposable sponge brush. Then attempted to mow the lawn (realized I didn't have gas, didn't feel like going out to buy any!) and came back 30 minutes later. At that point it was dry enough that I was able to clamp the piece in my brake and form the trim tab without any coming off the surface.
Dino Bortolin
601XL plans/Corvair
On 7/1/07, Arthur Olechowski <ifly4fun2(at)sbcglobal.net (ifly4fun2(at)sbcglobal.net)> wrote: [quote]Hi All,
AJ
[quote][b] http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com [quote][b]
Posted: Sun Jul 01, 2007 3:37 pm Post subject: Primer adhesion |
Kevin,
I've scuffed everything with 3M scotchbrite, degreased, alumiprep'd, alodined, rinsed and allowed it to dry overnight and then primed. I think I may have too thick of a coating.
AJ
kevinbonds <kevinbonds(at)comcast.net> wrote:
[quote] <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Are you scuffing the surface or chemical etching at all? I like Alumiprep. Also I am using Zinc Oxide in the rattle cans instead of Chromate. Think it is a little safer. Adhesion seems pretty good to me, and I live in <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Nashville, Tn. High humidity is just a fact of life here in summer.
Kevin Bonds
Nashville TN
I believe that may be my problem.
AJ
[quote] <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Also, a thin coating will adhere better than a thick one.
Kevin Bonds
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Nashville TN
Posted: Sun Jul 01, 2007 3:41 pm Post subject: Primer adhesion |
Rob,
I like your nifty plans storage desk on your site, not to mention your actual dedicated shop.
AJ
Robert Hansen <stol701(at)yahoo.com> wrote:
[quote] I just zinc chromated the skelaton from my 701 rudder and I live in the very dry Southern New Mexico. We do not measure humidity because we have none (joke). I too can scratch off the primer with my finger nail. Prior to spraying I cleaned up the metal with laquer thinner.
Rob Hansen
Posted: Sun Jul 01, 2007 3:47 pm Post subject: Primer adhesion |
Dred,
I agree, more cure time is necessary prior to assembly. Dryer weather would nice its been raining all week long. I think I should of cranked the AC on for awhile prior to priming to remove some of the humidity.
AJ
Edward Moody II <dredmoody(at)cox.net> wrote:
[quote] I'm not a paint expert..... in fact, I hate painting, but I think your problem is that you expected the primer to get hard much too fast. I have found that using self etching Zinc Oxide from rattle cans, cleaning the aluminum with laquer thinner (repeatedly until clean and fairly streak free) then following the directions works well. The primer can be scatched off pretty easily until it has had a few days to harden. Gradually it takes much more than a fingernail to get through it. You can etch before priming..... you can scratch the hell out of the parts with scotchbrite, emery cloth, a rock from the nearby streambed, whatever. But until the primer itself is tough, it can be pulled off the surface. Try giving it more time if you can.
Dred
Posted: Sun Jul 01, 2007 4:03 pm Post subject: Primer adhesion |
Dino,
I scuffed with 3M scotchbrite, degreased, rinsed then alumiprep'd and rinsed again then alodined and rinsed again allowed to dry overnight and then primed. I think the problem was the amount of primer applied was to thick with high humidity.
AJ
Dino Bortolin <dbortol(at)gmail.com> wrote:
[quote]I'm no expert on this, but it sounds like a surface preparation problem to me. I just zinc chromated the inside of my rudder trim tab yesterday. I scuffed the surface with a Scotchbrite pad, washed it with warm water and lemon-scented dish soap, and rinsed it with hot water. Didn't use any solvents. Let it air dry and brushed the chromate on with a disposable sponge brush. Then attempted to mow the lawn (realized I didn't have gas, didn't feel like going out to buy any!) and came back 30 minutes later. At that point it was dry enough that I was able to clamp the piece in my brake and form the trim tab without any coming off the surface.
Dino Bortolin
601XL plans/Corvair
On 7/1/07, Arthur Olechowski <ifly4fun2(at)sbcglobal.net (ifly4fun2(at)sbcglobal.net)> wrote: [quote] Hi All,
The only spray painting I've ever been exposed to is the type that comes out of a spray can. I used an HVLP sprayer with the reducer proportions as advised by PTI. The [quote][b]
p.mulwitz(at)worldnet.att Guest
Posted: Sun Jul 01, 2007 6:43 pm Post subject: Primer adhesion |
Hi AJ,
I have spent a lot of time and not a small amount of money
researching what paints will work on aluminum that I can get locally
and don't cost the earth to buy. The problem with aluminum is the
oxide that forms almost instantly prevents paint from sticking.
I have two different solutions - one for the interior paint and one
for exterior.
For the interior I wanted flat grey paint. This wound up being self
etching primer from SEM. I prep the surface with fairly coarse sand
paper (100 or 150 grit?) and clean it with lacquer thinner before
painting. This sticks like glue. For contrast on the interior
paint, I like flat black enamel in rattle cans. To get this to work
well with the self etching primer, I need to use an additional primer
in between the self etching primer and top coat. Without the
intermediate primer, the top coat nearly lifts the self etching
primer right off the aluminum.
For the exterior I am using the same self etching primer along with
epoxy primer and finally acrylic enamel. The last two products are
from PPG. This is less expensive than the popular urethane enamel
and is less toxic too.
Pricing for the self etching primer at my local professional paint
store runs about $12 for a rattle can and $22 for a quart. The PPG
epoxy primer and acrylic enamel run an average of around $100 per
gallon when you include the required hardeners and thinners.
For aircraft steel parts, the epoxy primer works incredibly well
directly on the steel. I don't think it needs a top coat if the
appearance isn't important like on the flap torque tubes.
Good luck,
Paul
XL fuselage
At 08:58 AM 7/1/2007, you wrote:
| Quote: | Hi All,
AJ
Posted: Mon Jul 02, 2007 2:10 am Post subject: Primer adhesion |
Thank You AJ,
My shop is nothing more then a metal building w/ a dirt floor. I posted my reply on the primer before waiting a couple days to see how it set up. I will be back at the "airplane factory" tonight, so I will see how it is doing.
Rob
Posted: Mon Jul 02, 2007 6:34 am Post subject: Primer adhesion |
All-
We may be talking apples and oranges here, because I'm using Zinc Oxide rather than Chromate.
This spring when we had high humidity from all the snow melting off it would take two days for parts to tack dry. It hasn't rained in a week and yesterday I shot a couple of parts and they were dry as a bone in an hour. Just an observation, not a hard and fast recommendation.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Float Flyr
Posted: Mon Jul 02, 2007 7:28 pm Post subject: Primer adhesion |
What colour Scotch Brite... Only kidding.... Let's not go there!
I read one post that said the builder alumipreped and then alodyned the
parts. I think that alumiprep with a water brake test is more than enough.
When you rinse the part if the water doesn't sheet off evenly then back to
scrubbing with the alumiprep, rinsing etc. etc..
Noel
| Quote: | Time: 04:35:01 PM PST US
Subject: Re: Primer adhesion
yesterday. I
warm water and
didn't have gas,
minutes later. At
piece in my brake
Dino Bortolin
601XL plans/Corvair
On 7/1/07, Arthur Olechowski <ifly4fun2(at)sbcglobal.net> wrote:
> Hi All,
PTI Zinc Oxide
advise on where to
> go from here.
type that comes
reducer proportions
with 72% humidity.
but the fully
allowed it to cure
chem-film with a
should do now?
> AJ
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Mon Jul 02, 2007 7:45 pm Post subject: Primer adhesion |
Rob,
I've placed a 1000W heat lamp (not facing any parts) with a circulating fan in the shop and have seen a substantial difference in the feel of the primer, at 93 deg and 53% humidity it is definitely curing now.
Art
[quote] Thank You AJ,
Rob
Posted: Mon Jul 02, 2007 8:02 pm Post subject: Primer adhesion |
Noel,
Well the wife picked up these multipurpose scotchbrite pads in bulk at Sam's there kind of nice cause they have a sponge on the opposing side too wipe the oxidation off with......just kidding. They were the real deal and water beading was non-existent when rinsing.
I believe the culprit is myself. Lack of spraying technique which resulted in a thicker than necessary coating in high humid conditions. The worst that can happen now is my CG shifts a tenth of an inch aft.
Art
Noel Loveys <noelloveys(at)yahoo.ca> wrote:
[quote]--> Zenith-List message posted by: "Noel Loveys"
Noel
[quote] Time: 04:35:01 PM PST US
yesterday. I
warm water and
didn't have gas,
minutes later. At
piece in my brake
Dino Bortolin
601XL plans/Corvair
On 7/1/07, Arthur Olechowski wrote:
> Hi All,
PTI Zinc Oxide
advise on where to
> go from here.
type that comes
reducer proportions
with 72% humidity.
but the fully
> cured in 30 minutes hasn't quite [quote][b]
barcusc(at)comcast.net Guest
Posted: Wed Jul 04, 2007 4:57 am Post subject: Primer adhesion |
I had the same problem with adhesion, I went to the House of Color and explained my problem and they recommended DuPont Etch Primer A-4115S. It works much better than anything I have used in the past.
Clyde Barcus
601 XL, Continental Powered
Wings, Tail & Engine Complete
Working on Fuselage
Posted: Wed Jul 04, 2007 6:29 am Post subject: Primer adhesion |
Thanks Clyde, I appreciate your input. I think I've looked into DuPont primer once before but was disgusted with the $200/gal price tag that came with it. How much does this stuff cost now and days?
Clyde Barcus <barcusc(at)comcast.net> wrote: [quote] I had the same problem with adhesion, I went to the House of Color and explained my problem and they recommended DuPont Etch Primer A-4115S. It works much better than anything I have used in the past.
Clyde Barcus
Working on Fuselage
