firewall penetration for the fuel line
dhall(at)donka.net
PostPosted: Fri Jun 29, 2007 3:45 pm    Post subject: firewall penetration for the fuel line Reply with quote
I am wrapping up fuse construction, I hope. About all that's left is mating
the wings and running fuel and brake lines. I have the airflow performance
setup. I'm trying to connect up as much of the fuel lines as I can now, but
I have not purchased the firewall forward kit, and the plans do not show any
details about firewall penetration and purge lines.
Is it best to ignore this and just focus on hooking the tank lines up to the
fuel selector and pump for now? (It's all that the plans are clear on.)
Then move on to the finishing kit and worry about the rest of the fuel
system design later when I'll have had longer to do some research and
overcome the learning curve... Or must I face this beast now when things
are clearly more accessible?
Also, is it worthwhile to go ahead and install rudder pedals and the brake
lines now? Seems it'll just be in the way when I do finally run fuel lines
out to the firewall.
Don
dstorer(at)atlinkwifi.com
PostPosted: Sun Jul 01, 2007 8:31 am    Post subject: firewall penetration for the fuel line Reply with quote
PostPosted: Sun Jul 01, 2007 9:20 am    Post subject: firewall penetration for the fuel line Reply with quote
