rhdudley1(at)bellsouth.ne Guest
Posted: Wed Jun 27, 2007 6:24 pm Post subject: Rudder Lock |
Gary,
I've made a rudder lock for my RV-6A after seeing a concept at Sun N Fun a year ago. So, I don't take credit for the idea. I found a simple and cheap way to make one out of PVC pipe and one "T" fitting. I was planning to give more detail for anyone who might think it useful. Then, I read your post. I've been using my seat belt on the stick for elevator and ailerons. I don't have the rudder lock here to quote the dimensions, but you can get an idea of the concept from the photos. I'll post the rest of the info when I get a chance. You can see that it is very simple and cheap. It merely requires a piece of PVC pipe, a "T" and a union cut to hold the splayed halves of the pipe and come PVC Cement.
Richard Dudley
RV-6A flying
51.03 KB |
642 Time(s) |
69.13 KB |
595 Time(s) |
24.34 KB |
495 Time(s) |
rv7(at)b4.ca Guest
Posted: Wed Jun 27, 2007 8:22 pm Post subject: Rudder Lock |
On 19:22 2007-06-27 Richard Dudley <rhdudley1(at)bellsouth.net> wrote:
| Quote: | I've made a rudder lock for my RV-6A after seeing a concept at Sun N
Just thinking out loud here, maybe you could make two smaller fittings that
go on either end of the removable passenger stick. Remove stick, apply
fittings, lock rudder. The smaller fittings might stow easier.
-Rob
ronlee(at)pcisys.net Guest
Posted: Thu Jun 28, 2007 5:30 am Post subject: Rudder Lock |
| Quote: | Just thinking out loud here, maybe you could make two smaller fittings
that
My view is that the internal gust locks MUST be on the pilots side. That
way you can't take off with them in place.
Ron Lee
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Thu Jun 28, 2007 6:02 am Post subject: Re: Rudder Lock |
I never say never because I'm human but I've never taxiied out to take off and NOT unfurled a checklist and not followed the "flight controls -- free and correct" part first. Of course, after I go through a checklist, I go through it a second time (without the mag check) to be sure I got everything. Since I've never not done a run-up check, and since flight controls are the first thing I check (and the last thing I check), that goes a long way to preventing me from making a stupid mistake.
So it leads me to wonder how many pilots aren't doing run-ups and checking the controls and, if they aren't, why aren't they?
True enough, it only takes one time but under what circumstances would one not do a run-up check before trying to fly?
This situation of taking off with gust locks and rudder locks would be, perhaps, more understandable in a 172 or a Warrior or a spam can with lousy visibility. But an RV?
Seems to me that for this to happen you not only would have to have NOT done a proper pre-flight, you also wouldn't have done a proper run-up check.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Posted: Thu Jun 28, 2007 6:07 am Post subject: Rudder Lock |
| Quote: | My view is that the internal gust locks MUST be on the pilots side. That
Ron Lee
Perhaps someone can find the report about the RV pilot who died in a fire
after his plane pitched up after takeoff and crashed. Reportedly he used
a passenger side seat belt gust lock and was in a hurry to leave the
airport.
No need to repeat that fatal move folks.
Ron Lee
rv7(at)b4.ca Guest
Posted: Thu Jun 28, 2007 6:37 am Post subject: Rudder Lock |
On 6:28 2007-06-28 "Ron Lee" <ronlee(at)pcisys.net> wrote:
> fittings that
> apply fittings, lock rudder. The smaller fittings might stow
easier.
That way you can't take off with them in place.
I agree, and wasn't meaning to suggest otherwise. But there's no reason
you couldn't use the passenger stick tube as part of that lock, and save
carrying yet another tube in the airplane.
-Rob
n616tb(at)btsapps.com Guest
Posted: Thu Jun 28, 2007 8:04 am Post subject: Rudder Lock |
It is in Bob's RV Hotline page.
(http://rvhotline.expercraft.com/articles/2007/eaa_court_motion_result.html)
Tim
[quote] --
