CJohnston(at)popsound.com Guest
Posted: Tue Jun 26, 2007 11:34 am Post subject: smaller diameter scat tubing in the tunnel? |
Hey all -
Perused the archives but could find nothing relating, so here goes...
has anyone thought about using smaller diameter scat tubing in the
tunnel to route heat to the rear pax? I know you'd need to neck it down
somehow to attach, but it'd make the tunnel a bit less tight with
everything that's going on in there. what say you all?
cj
#40410
fuse/finishing
www.perfectlygoodairplane.net
