steve.didier(at)gmail.com Guest
Posted: Sat Jun 23, 2007 4:24 pm Post subject: Kitfox and Jab 3300 |
Has anyone mounted a Jabiru 3300 to a later model Kifox---series 5 to
current? If so how did it change your w/b, cruise, climb etc compared
to the Rotax 912?
thanks in advance!
Steve Didier
darinh
Posted: Sun Jun 24, 2007 2:38 pm Post subject: Re: Kitfox and Jab 3300 |
I know of one guy who is in the process of doing this. He should be working on flight testing now. I am awaiting a report of his performance and will relay them when I find out.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Posted: Sun Jun 24, 2007 3:24 pm Post subject: Kitfox and Jab 3300 |
Darin, How do you like the performance of your 914 turbo? Do you think
the added initial expense is worth the performance increase, and what
kind of fuel burn do you have/
Steve Didier
On Sun, 24 Jun 2007 15:38:52 -0700, darinh wrote:
Darin Hawkes
Series 7 (under Construction)
914 Turbo
Ogden, Utah
http://forums.matronics.com/viewtopic.php?p=120402#120402
darinh
Posted: Sun Jun 24, 2007 7:44 pm Post subject: Re: Kitfox and Jab 3300 |
Steve,
I haven't flown it yet as I am still under construction so I can't tell you from first hand experience. However, there are two guys up in Idaho (Maybe Mark will chime in on the performance of his 914) that are running the 914 and they say the performance is amazing! Fuel burn is not much different from the 912s because you throttle back to around 60% - 65% during cruise and get speeds in the 120-130 range. Mark says he can easily hit the 140 Vne in his series 7 and he says the deck angle during climb out can be scary if you push it.
As far as the initial cost goes, it is substatially more than the 912s but I will take my chances that the performance is going to make up the difference. I do a lot of my flying in the high elevations of Utah, Idaho and Montana and as far as I am concerned, HP is my friend.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Sun Jun 24, 2007 10:04 pm Post subject: Kitfox and Jab 3300 |
Thanks Darin, I live in north central Idaho, right next to the Selway.
I drive a 172 and am seriously considering building the Kitfox. John
McBean gave me a ride in the Super Sport last week and I was very
impressed with the 912s performance especially compared to our Cessna.
Right now I am just trying to get as much information as I can before I
finally take the plunge!
Steve Didier
On Sun, 24 Jun 2007 20:44:37 -0700, darinh wrote:
Steve,
Darin Hawkes
914 Turbo
Ogden, Utah
http://forums.matronics.com/viewtopic.php?p=120451#120451
darinh
Posted: Mon Jun 25, 2007 12:04 pm Post subject: Re: Kitfox and Jab 3300 |
Steve,
I think you will find that the Kitfox is hard to beat in that area...especially when you consider the cost of other aiplanes that will get you in and out of the mountains. I previously owned a Model 3 Kitfox and took it into a bunch of the stips up near you. It was a great bird but I wanted a bit more speed to travel from Utah up to the good flying country, hence the 7 with the 914. It will give me good speed and great climb performance.
Where about in Central Idaho are you? We have a cabin and short strip just over the hill from Shoup, Id
Series 7
914 Turbo
Kaysville, Utah |
Posted: Mon Jun 25, 2007 1:32 pm Post subject: Kitfox and Jab 3300 |
Thanks for the info Darin. My home field is S73 Kamiah but my ranch is
just outside of Clearwater. From Shoup that would put us around 70-90
air-miles NNW. My plan is to put in a strip just outside of the back
door (1,000') and it will be aligned with the prevailing winds 98% of
the time.
Steve
On Mon, 25 Jun 2007 13:04:41 -0700, darinh wrote:
Steve,
Darin Hawkes
914 Turbo
Ogden, Utah
http://forums.matronics.com/viewtopic.php?p=120571#120571
