jrpearson(at)brant.net Guest
Posted: Mon Jun 25, 2007 3:54 am Post subject: Shower of Sparks |
I've gone through 2 shower of spark units and am wondering if I'm doing something wrong!!!
Is there an alternate unit like a solid state system or something. Is there a problem with reliability with the standard russian unit?
J.Pearson
george(at)gesoco.com Guest
Posted: Mon Jun 25, 2007 4:41 am Post subject: Shower of Sparks |
It does not sound normal to burn those up. We seldom replace them. Perhaps your wiring is wrong and it is running too often. It should only be active when you press the start button.
I made a few solid state units a few years ago, but the Russian units were so low cost that it did not pay to produce them. You can always use a spare MODEL T coil unit if you have on handy. The T-6 guys also have a unit that most home builders use.
George S. Coy
President
Gesoco Industries Inc.
629 Airport Rd.
Swanton, VT 05488 USA
George(at)gesoco.com (George(at)gesoco.com)
george.coy(at) gmail.com
Phone +1-802-868-5633
Fax +1-802-868-4465
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of John Pearson
Sent: Tuesday, June 26, 2007 6:56 AM
To: M14PEngines-List(at)matronics.com
Subject: Shower of Sparks
J.Pearson
href="http://www.matronics.com/Navigator?M14PEngines-List">http://www.matronics.com/Navigator?M14PEngines-List
culpspecial(at)yahoo.com Guest
Posted: Mon Jun 25, 2007 4:54 am Post subject: Shower of Sparks |
We stock the Russian shower of sparks and sell 1 or 2 a week and usually don't see any problem with them. Seems like most of them last 20 years or so.
Check out the wiring like George suggested and if they are not adjusted properly it can cause them to overheat which can cause the coil to crack.
I have seen people not ground them internally. You would think the housing is grounded to the points but you have to have a ground run to one of the terminals inside. But this just keeps them from working.
Steve Culp
Culp's Specialties
www.culpsspecialties.com
318 222 0850 phone & fax
George Coy <george(at)gesoco.com> wrote:
[quote] It does not sound normal to burn those up. We seldom replace them. Perhaps your wiring is wrong and it is running too often. It should only be active when you press the start button.
George S. Coy
President
629 Airport Rd.
Fax +1-802-868-4465
Subject: [quote][b]
