		VE3LVO(at)rac.ca Guest
				 Posted: Thu Feb 09, 2006 10:51 am    Post subject: Cabling |
				Cheers,
             Monowheel classic 914 Europa here, about to hang engine.
             If you have done this, what amount of cabling (cockpit to
 engine) have you covered with firesleeve?  Did you revise/modify any of it?
 Do you remember how much firesleeve and sizes you got to complete the task?
             And even more vital, are you willing to share the info?
 Signed, Desparate
 Actually , Ferg
 A064
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		gfmjr_20(at)hotmail.com Guest
				 Posted: Thu Feb 09, 2006 2:28 pm    Post subject: Cabling |
				Ferg--
   Just finished installing the 912s on my Zodiac 601XL.  With boost pump in
 parallel with engine pump. I used about 18ft of firesleeve. All sleeving
 was in engine compartment. Fire sleeve was 1/2 inch
 George
  	  | Quote: | 	 		  From: "Fergus Kyle" <VE3LVO(at)rac.ca>
 Reply-To: rotaxengines-list(at)matronics.com
 To: <rotaxengines-list(at)matronics.com>
 Subject: Cabling
 Date: Thu, 9 Feb 2006 13:52:49 -0500
 Cheers,
 Signed, Desparate
 Actually , Ferg
 A064
 Express yourself instantly with MSN Messenger! Download today - it's FREE!
 http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
		malann(at)bigfoot.com.au Guest
				 Posted: Fri Feb 10, 2006 2:12 am    Post subject: Cabling |
				Hi Ferg,
 16-20 feet sounds about right. I used -8 firesleeve ie 1/2".
 A tip given to me by another builder: it is possible to sheath flexible
 fuel hose with firesleeve too tight to push the hose into by using
 compressed air. Firesleeve needs to be longer than the hose. Clamp off one
 end of the firesleeve. insert compressed air into the hose then put the
 other end into the firesleeve. It will expand the firesleeve enough to
 allow easy fitting. The end result is nice looking line with smooth fitting
 firesleeve.
 Malcolm Ferguson
 Esqual 912s
 No virus found in this outgoing message.
 Checked by AVG Anti-Virus.
 Version: 7.1.375 / Virus Database: 267.15.3/254 - Release Date: 08-Feb-06
