GX-65 pin out
bobf(at)feldtman.com
PostPosted: Sun Jun 24, 2007 4:32 am    Post subject: GX-65 pin out Reply with quote
Bob - where is an easy internet site to find the pinout diagram for Apollo GX-65? I know the GPS data output I need is on pin 5 (to power a trio autopilot) but would like to confirm the pinout and be sure the numbering system I have in my mind is from the "back" of the unit looking at the serial port - thanks
bobf
recapen(at)earthlink.net
PostPosted: Sun Jun 24, 2007 3:54 pm    Post subject: GX-65 pin out Reply with quote
One of the websites of one of the guys that frequent these lists has some of the older manuals linked or on his site.
I have a GX60 - I'll look at my manual........
PostPosted: Sun Jun 24, 2007 4:21 pm    Post subject: GX-65 pin out Reply with quote
thanks Ralph! I'fe found the manual on line but it does not have a pinout.diagram, nor a list of the pin numbers and what they are. I did find on the tru trak web site that 5 is GPS and 22 if the GX has GPSS
thanks
bob
On 6/24/07, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:[quote] One of the websites of one of the guys that frequent these lists has some of the older manuals linked or on his site.
gyoung
PostPosted: Sun Jun 24, 2007 6:25 pm    Post subject: GX-65 pin out Reply with quote
I've attached a UPS full stack wiring diagram that includes the GX-60/65 (same pin-outs). In case it doesn't come thru:
RxD1 = pin 4
Serial Gnd = pin 3
TxD1 = pin 5
TxD2 = pin 22
Serial gnd = pin 20
RxD2 = pin 21
If you look closely at the connector, the pin numbers are molded into the plastic. I need really good light and/or magnifying glass to read them, but they are on all my UPS radios with D-Subs.
Greg Young - Houston (DWH)
RV-6 N6GY ..project Phoenix
Navion N5221K - just an XXL RV-6A
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert Feldtman
Sent: Sunday, June 24, 2007 7:31 AM
Subject: GX-65 pin out
bobf
fullstackwiring.pdf
 Filename:  fullstackwiring.pdf
 Filesize:  80.35 KB
 Downloaded:  397 Time(s)
PostPosted: Sun Jun 24, 2007 6:49 pm    Post subject: GX-65 pin out Reply with quote
thanks Greg!
bobf
N125GS
On 6/24/07, Greg Young <gyoung(at)cs-sol.com (gyoung(at)cs-sol.com)> wrote:[quote] I've attached a UPS full stack wiring diagram that includes the GX-60/65 (same pin-outs). In case it doesn't come thru:
RxD1 = pin 4
Serial Gnd = pin 3
TxD1 = pin 5
TxD2 = pin 22
Serial gnd = pin 20
RxD2 = pin 21
RV-6 N6GY ...project Phoenix
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Robert Feldtman
bobf
