		hotwheels
				 Posted: Thu Jun 21, 2007 2:03 am    Post subject: parking brake cable |
				What sort of cable/control should I order for my Matco Parking Brake? Vendor?
 Where have others terminated it under the panel?
 Thanks in advance for replies!
 Jay
 Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
 http://answers.yahoo.com/dir/?link=list&sid=396545469
				 Posted: Thu Jun 21, 2007 6:19 am    Post subject: parking brake cable |
				I got the one with a pushbutton in the center....haven't figured out where it's going yet though......
		LloydDR(at)wernerco.com Guest
				 Posted: Thu Jun 21, 2007 6:47 am    Post subject: parking brake cable |
				I got the one from Aircraft Spruce that ratchets and releases with a
 quarter turn. I mounted the valve on the firewall, next to the brake
 line standoffs. Then routed the cable forward to a sub panel attached to
 the main panel and in easy reach of the pilot.
 Dan
 N289DT RV10E
		scottmschmidt(at)yahoo.co Guest
				 Posted: Thu Jun 21, 2007 7:33 am    Post subject: parking brake cable |
				For my parking brake I used the same push pulls that Van's gives you in the kit.  I then did some bending and riveting of some aluminum and made some stops for the arm and placed a spring on the arm so it would be in the open position.  I then placed a micro switch on the assembly that was attached to a light on my panel.  The light is off only if the arm is in the full open position. So far it has worked great.
 Scott Schmidt
 scottmschmidt(at)yahoo.com
				 Posted: Thu Jun 21, 2007 8:01 am    Post subject: parking brake cable |
				I like the idea of a parking brake light, I will have to  make that mod.
  THX for the idea
  Dan
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott  Schmidt
 Sent: Thursday, June 21, 2007 11:33 AM
 To:  rv10-list(at)matronics.com
 Subject: Re: parking brake  cable
 Scott Schmidt
  -----  Original Message ----
 From: "Lloyd, Daniel R."  <LloydDR(at)wernerco.com>
 Sent: Thursday,  June 21, 2007 7:46:47 AM
 Subject: RE: parking brake cable
  --> RV10-List message posted by: "Lloyd, Daniel R."  <LloydDR(at)wernerco.com>
 Dan
 N289DT RV10E
		AirMike
				 Posted: Fri Jun 22, 2007 6:53 am    Post subject: parking brake cable |
				Lloyd - do U have the numer of the spruce product?
 I was also remided that you should make sure that you have a positive release system. If you are flying an land with the brake on - baaaaad things could happen.
  _________________ See you OSH '18
Q/B - sold. |
				 Posted: Sun Jun 24, 2007 5:24 pm    Post subject: parking brake cable |
				T-handle dash contrl 1 wire 8 feet
 p/n 05-15100
 Hope this helps
 Also I attached a spring to the control arm to ensure it would be pulled
 back when the handle was released
