John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Sat Jun 16, 2007 6:51 pm Post subject: Oil Cooler |
For those of us who fly where it's goshawful hot, (Phoenix area) it
seems to make good sense to install a high-capacity oil cooler. I'd
certainly like to have enough capacity that the vernitherm nearly
always controls the oil temperature.
This point of view is supported by a highly respected engine builder,
and by Vans tech support.
Here are some options that I'm aware of:
1. Replace the Niagara 20006A that Vans supplies with a higher
capacity unit of the same dimensions, such as the Stewart Warner
10611R, which transfers _very_ roughly 20% more heat, I'm told.
2. Put in a larger (17-row) cooler such as (in order of increasing
capacity) Niagara 20010A, Aero Classics 800216 or 800356, or Stewart
Warner 10614R.
3. Increase the airflow somehow, such as by incorporating vents or
louvers in the lower cowl.
I'd love to put in a SW 10164 (R, I think) but it's about 1.5"
longer that the stock unit. Just holding the engine mount up to the
firewall, it looks to me like there would be inadequate clearance,
because that 1.5" has to come at the bottom - the starter solenoid
and associated structure prevent moving it up.
Has anyone put in a larger cooler? If so, what are your
observations? What experiences do those who are already flying have?
I don't pretend to be expert on oil coolers - the above differences
are based only on what I've been told by what I believe to be
reliable folks, and on the Stewart Warner data sheets on the web.
John Ackerman 40458 finishing kit
do not archive - just archive the answers, please!
Tim Olson
Posted: Sat Jun 16, 2007 7:06 pm Post subject: Oil Cooler |
If you go with increased cooling, add some method of controlling
that added cooling. On the trip I'm currently on, I had some time
on a leg that I couldn't get my oil temps over 171, which is a
little on the low side. Std. cowl and filter.
Warner 10614R.
coop85(at)cableone.net Guest
Posted: Sat Jun 16, 2007 8:33 pm Post subject: Oil Cooler |
John,
For what it's worth, I've been flying mine on some pretty hot days in
Georgia and Mississippi with no issues on oil temperature with the standard
system on almost 100 degree days. I realize it does get hotter in Phoenix,
I built a Q-2 there glassing the inside of the tailcone on the driveway the
day it hit 122 degrees (probably more sweat than resin in those layups).
Anyway, if you don't get a response from someone with experience with a
higher flow system, I'd recommend giving the standard a shot and see how it
goes. One advantage of that area is it seems to cool off more rapidly as
you climb (dry heat I guess), so if you don't cruise low altitude that may
help the issue as well.
Marcus
mritter509(at)msn.com Guest
Posted: Sun Jun 17, 2007 4:13 am Post subject: Oil Cooler |
John,
My oil temp came down from 215 to 200 after 50 hours using a Van issue oil
cooler. After adding louvers on the bottom cowl the temp is now running 185
on hot Texas days.
Mark
[quote]From: "Marcus Cooper" <coop85(at)cableone.net>
Subject: RE: Oil Cooler
Date: Sat, 16 Jun 2007 23:32:27 -0500
John,
Marcus
John Ackerman
Posted: Mon Jun 25, 2007 4:31 pm Post subject: Oil Cooler |
Thanks, guys, for the information.
Sounds like Mark's cooler may be running at full capacity a lot of
the time, still.
I'll be using a SW 10611 cooler which has the same dimensions as
Van's Niagara 20006A. If CHTs and oil temps are still too hot after
10-20 hours, (new engine) louvers will be on the list of fixes.
John
On Jun 17, 2007, at 5:12 AM, Mark Ritter wrote:
John,
issue oil cooler. After adding louvers on the bottom cowl the temp
is now running 185 on hot Texas days.
Mark
> To: <rv10-list(at)matronics.com>
> John,
> days in
> standard
> Phoenix,
> driveway the
> layups).
> with a
> see how it
> rapidly as
> that may
> Marcus
