JetPilot
Posted: Fri Jun 22, 2007 9:18 am Post subject: Setting up Rotax 447 Prop and Mixture, how do I do it ??? |
Here is a question for all you 2 stroke experts. I have a Rotax 447 that I just bought a new powerfin adjustable prop for. How do I set it up for EGT's ? I am going to set the pitch so that it is maximum torque at WOT, not redline the rpm ! What EGT should I be looking for ? With the old wood prop on there, it ran fine, but it would tend to bog down and die if I let it to idle and increased the throttle rapidly. Only giving throttle very slowly would save it. I think that means a rich idle, but im not totally sure. Any advice on how to set up and jet this engine for the new prop and sea level altitude would be appreciated.
Mike
Kolb MK-III Xtra, 912-S |
