RV7 main gear wood dampeners
pwatsonfnp(at)comcast.net
PostPosted: Thu Jun 21, 2007 9:33 am    Post subject: RV7 main gear wood dampeners Reply with quote
I am finishing up my 7 and working on the main gear fairings. Does anyone have any comments on installing the wood main gear dampeners? Anyone not installed them? Other ideas?
Paul Watson
tscaragol(at)aol.com
PostPosted: Thu Jun 21, 2007 11:51 am    Post subject: RV7 main gear wood dampeners Reply with quote
I read a report abt shooting foam into the area and I did that. It worked OK, but I'll give you a few things to be carful abt if you do use the foam into the open area. First, make very sure you will not have to change the fairings later. n other words, have the wheel pants & the upper leg fairings all set and make sure the fairings are aerodinamically set where they need to be before you begin. You have to do this anyway or should as is shown in the plans. If you use this method, get a longer tube to shoot the foam in so you get it abt to the center of the fairing. Stop squirting the foam in well before you get to the top or bottom because the foam really expands and will come out the top & bottom & then you've got a mess.  I did mine that way & I've been flying for 2 years and still fine. I've noticed when I taxi, you can hear the foam moving, but the gear will flex no matter what you use. Hope this helps. Tony
mtaylo17(at)msn.com
PostPosted: Thu Jun 21, 2007 3:12 pm    Post subject: RV7 main gear wood dampeners Reply with quote
I didn't bother with the wood, but did the foam method. Works great. My wheels have never shimmied like Mike Seager's training RV-7.
Mark.
www.4sierratango.com
[quote] From: pwatsonfnp(at)comcast.net
To: rv7-list(at)matronics.com
Subject: RV7-List: RV7 main gear wood dampeners
Date: Thu, 21 Jun 2007 10:32:42 -0700
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass EC_a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass EC_span.EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Paul Watson
et=_blank>http://www.matronics.com/Navigator?RV7-List
p://forums.matronics.com
exodus(at)gds.co.za
PostPosted: Thu Jun 21, 2007 8:34 pm    Post subject: RV7 main gear wood dampeners Reply with quote
I installed wood dampeners and I find I should have made them thicker (maybe a harder wood as well) as I still pick up a shimmy when taxiing on an uneven tar surface. I have to use the brakes to stop the shimmy, so yes, they should be fitted.
Cliff Lotter
theo.celis(at)skynet.be
PostPosted: Fri Jun 22, 2007 1:50 am    Post subject: RV7 main gear wood dampeners Reply with quote
We used stiff Meranti (about 700kg/m3) glued with TEC-7 a urethane based strong glue
that remains slightly flexxible.
Théo.
RV-7A
 Filesize:  513.02 KB
 Viewed:  682 Time(s)
