ben_ramler2002(at)yahoo.c Guest
Posted: Sun Jun 17, 2007 11:12 am Post subject: green paint |
Hi everyone,
When I was at Rogers place i noticed he painted some green ant-corrosion paint on certain places. My question this does anyone know what the name of it is and don't you have to paint the whole entire airplane with this stuff or no?
thanks,
Ben
Zenith wanna-be
Sick sense of humor? Visit Yahoo! TV's [url=http://us.rd.yahoo.com/evt=47093/*http://tv.yahoo.com/collections/222]Comedy with an Edge [/url]to see what's on, when. [quote][b]
dredmoody(at)cox.net Guest
Posted: Sun Jun 17, 2007 11:34 am Post subject: green paint |
We've been through this in the archives pretty thoroughly but the short version is:
You really only need to prime the places where two parts touch because moisture will wick in and remain there often. Remember the places where skins overlap.
I chose to prime the entire inside of mine so that anything that won't be painted later for esthetics will be at least be primed for protection.
The green stuff (also available in gray) is likely either Zinc Chromate (very toxic.... be careful) or Zinc Oxide (somewhat more friendly) self etching primer. I used Tempo Zinc Oxide from rattle cans and bought it at Aircraft Spruce.
The water based stuff, Cortec, seems to be okay too.
If you don't do at least some of the above, you should use the spray-the-inside-of-the-plane stuff once a year or so.
Dred
jimandmandy(at)yahoo.com Guest
Posted: Tue Jun 19, 2007 8:55 pm Post subject: green paint |
It also comes in yellow. I have never seen gray. Due
to the fact that mine will most likely live outside in
a coastal environment, I'm using zinc cromate on all
interior surfaces that will be closed up and therefore
not easily inspected for corrosion.
--- Edward Moody II <dredmoody(at)cox.net> wrote:
[quote] We've been through this in the archives pretty
overlap.
once a year or so.
Dred
