grantn
Joined: 04 Nov 2006 Posts: 11 Location: Campbell River, B.C. Canada
Posted: Fri Jun 15, 2007 2:17 pm Post subject: Connector for copilot stick grip |
I'm setting up dual trim and dual PTT in my RV9A using RAC pistol grips on both pilot & copilot sides, but would still like to remove the copilot stick once in a while when the wife stays home and I want to carry extra baggage on the passenger side. I'm wondering what others have done to allow quick disconnect and removal of the copilot stick. The inside diameter of the stick is about 3/4 inch, and I would need a six pin (circular?) connector. Any photos of others' efforts and sources for such a connector would be greatly appreciated.
Grant Neilson
RV9A, wiring
[img]cid:187350422(at)15062007-1223[/img]
3.69 KB |
2913 Time(s) |
15.13 KB |
529 Time(s) |
jonlaury
Posted: Sat Jun 16, 2007 8:57 am Post subject: Connector for copilot stick grip |
Run your wiring out the bottom/side of your stick to a plug that is below your upholstery line. Use a quick disconnect pin (AC Spruce) or a bolt for the stick. Unplug, unbolt/disconnect, stow stick, load piano.
J
