g-iani(at)ntlworld.com Guest
Posted: Mon Jun 11, 2007 1:39 am Post subject: Rotax Circuit Wiring |
The diagram that Ivor has sent you is the correct one.[b].[/b]
Some of the wires (which you are unlikely to get wrong as they are already connected) are not marked on the diagram. For information here are the rest. T[b]hese are shown on the wiring harness diagram. I have a very tatty paper copy but have never found a PDF.[/b]
12,24,17 and 36 are the serial connection (for setting the throttle etc)
7, 13 and 19 also go to the turbo servo but are not shown on the diagram
3 and 4 are the air box temperature sensor
15 and 27 are the taco connections
5 and 22 are the card air box solenoid
8,20 and 32 go to the throttle position sensor
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
Posted: Mon Jun 11, 2007 8:48 pm Post subject: Rotax Circuit Wiring |
Hi! Ian
Thanks for helping with my frustration! Your numbers help close the circle somewhat ….further brain scans likely !
It would have helped if Skydrive had put their photocopy of a picture of connecting the mags to the panel anywhere but stapled to the back of the oil priming documents !
Bob H
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of G-IANI
Sent: 11 June 2007 10:38
Subject: RE: Rotax Circuit Wiring
n100rh(at)sbcglobal.net Guest
Posted: Tue Jun 12, 2007 5:52 am Post subject: Rotax Circuit Wiring |
Robert,
Thanks for your timely question on the mag wires. However, I am still
very confused, I can't figure where the mag wires are, or where they
come out of the A & B boxes. The Rotax diagram shows shielded leads
running from the boxes and to the mag switches. I am really feeling like
a retard!
Ralph
R.C.Harrison wrote:
Hi! Ian
Bob H
Robt.C.Harrison
josok-e(at)ukolo.fi Guest
Posted: Tue Jun 12, 2007 9:16 am Post subject: Rotax Circuit Wiring |
Hi All,
The mag wires are not there, not anymore on newer engines.
Take a close look at the connectors of the ignition units, there is one
wire missing on both, that's were the tiny spade connector goes with the
shielded wire you supply. And don't forget the tiny rubber grommet, that
should keep the water out of that connector.
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
Posted: Tue Jun 12, 2007 10:31 am Post subject: Rotax Circuit Wiring |
Hi! Ralph
You aren't retarded .....well any more than myself !
Wow! a couple of days ago I was "pigged off" and now find myself helping others in distress ! thanks for the opportunity.
I don't study modern circuit diagrams very amiably, or sit and read instructions on a VDU screen either. However at the expense of asking I'm pleased to say the answer is simple ...Rotax don't do shielded mag. kill wires and switches in spite of very adequately providing all the other wires, shielded in the case of alternator wires (yellow) and posh black nylon sleeve round them too. Thanks to my pal Ivor Phillips I can advise that you need to provide your own shielded wire and switches for the job.
In my case no big deal since my Jabiru wires are adequate to swap straight over. All you need to know further is the location of the engine end and where to fix them..... On the top of the engine you will find a couple of cigarette size black boxes and some electrical connect plugs. These are A and B shown on the circuit drawing. In the corner each of the connectors you will find what appears to be one location without a wire in seemingly blanked off. If you carefully (using a sewing needle) prick into and prise out the black blanking material you will find it to be a rubber grommet (be careful since to " have them go walk about you won't find them again !)
Now in your kit you will find either a couple of bullet connectors (older engine packs) or a pair of bright silver slim spade connectors these connectors need crimping to the wires which you have provided along with the grommets so that when inserted back in the connector holes they will seal against ingress of water.
Ian Rickard kindly furnished me with the "key" numbers of the remaining wires which I'm sure is useful to know, I've copied them below for your info.
Bob Harrison G-PTAG with thanks to all who messaged to help on my cry of frustration !
Gilles.Thesee(at)ac-greno Guest
Posted: Tue Jun 12, 2007 10:35 am Post subject: Rotax Circuit Wiring |
Ralph K. Hallett III a écrit :
<n100rh(at)sbcglobal.net>
Robert,
Ralph and all,
Rotax has changed his mag connectors.
I just crafted a quick web page on the subject at
http://contrails.free.fr/engine_rotax_mag_connect_en.php
Maybe this could be of some help.
Best regards,
Gilles
Posted: Tue Jun 12, 2007 10:40 am Post subject: Rotax Circuit Wiring |
OMG! Now how was I supposed to know that????
Oh, I feel like I just got off the short bus Thanks much,
Ralph
Jos Okhuijsen wrote:
Hi All,
one wire missing on both, that's were the tiny spade connector goes
with the shielded wire you supply. And don't forget the tiny rubber
grommet, that should keep the water out of that connector.
Jos Okhuijsen
--workshopcam http://www.okhuijsen.org/plane
Posted: Tue Jun 12, 2007 1:36 pm Post subject: Rotax Circuit Wiring |
Thanks again to all, great help! Maybe, some day I can return the
favor... let's hope so.
Ralph
Hi All,
Jos Okhuijsen
