Air venting
rstone4(at)hot.rr.com
PostPosted: Sun Jun 10, 2007 8:01 am    Post subject: Air venting Reply with quote
Does anyone know of air vents that are available to be fitted to the side of the cockpit skin to direct outside air on the pilot and passenger, I am looking for the type that have a flange on the outside to cover a rough cut opening. Metal or plastic of good quality is desired. If so, I would like to see some pictures or be directed where I can see pictures.
In trying to solve a problem of high cockpit heat, I installed heat shield materiel on the firewall and wrapped some tape around the exhaust pipes made by Thermo Tec. This reduced the amount of heat signifently, however it's still too warm for summer flying here in Central Texas
Tracy Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
craig(at)craigandjean.com
PostPosted: Sun Jun 10, 2007 8:53 am    Post subject: Air venting Reply with quote
Do you mean in addition to the factory NACA vents?
How about a vent in the canopy? Spruce p/n CC3251 or 05-01179. Cut the hole by hand with a fly-cutter in under an hour. Pictures attached of a vent installed on Doug Dugger's plane.
http://www.aircraftspruce.com/pdf/2007Individual/Cat07190.pdf
-- Craig
 Filesize:  40.45 KB
 Viewed:  542 Time(s)
 Filesize:  31.38 KB
 Viewed:  577 Time(s)
 Filesize:  32.24 KB
 Viewed:  540 Time(s)
 Filesize:  37.48 KB
 Viewed:  534 Time(s)
sonar1(at)cox.net
PostPosted: Sun Jun 10, 2007 9:14 am    Post subject: air venting Reply with quote
Hi Robert/Tracy Stone:
Check out Vans. They have a vent that fits in the wall, and puts a scoop
out into the slipstream. I got two, installed one, but haven't flown
with it yet.
They also have adapters for the plastic eyeballs, and cheap air hose.
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1181495301-506-117&browse=heatvent&product=10vent_kit
Fred Sanford 601XL Jab 60%
larry(at)macsmachine.com
PostPosted: Sun Jun 10, 2007 1:21 pm    Post subject: Air venting Reply with quote
robert stone wrote:
*Tracy,
You can make your own channel for the inside behind a NACA opening and
add a louvered adjustable air vent out
of a GM auto for very little. They work very well so long as you
position the NACA intake at or forward of the leading
edge of the aircraft. Air vents over the wing can actually suck air
from the cabin or minimize the flow due to wing lift.
I built my own and it only takes a little time. There are commercial
equivalents, but most get into your panel with a
spherical vent. The GM vents are cylindrical and have adjustable
louvers. About $3.00 for both. See links,
http://www.macsmachine.com/images/largeassembly2/full/NACAvent.gif
http://www.macsmachine.com/images/largeassembly2/full/freshairassy.gif
http://www.macsmachine.com/images/largeassembly2/full/freshairassy2.gif
http://www.macsmachine.com/images/largeassembly2/full/outletventright.gif
http://www.macsmachine.com/images/largeassembly2/full/outletvent.gif
http://www.macsmachine.com/images/completion/full/601ezclosefrtrt.gif
Larry McFarland at www.macsmachine.com
Central Texas
Tracy Stone
Harker Heights, Tx
NYTerminat(at)aol.com
PostPosted: Sun Jun 10, 2007 7:31 pm    Post subject: Air venting Reply with quote
Larry, That is a real work of art Smile
Bob Spudis
In a message dated 6/10/2007 5:23:07 P.M. Eastern Daylight Time, larry(at)macsmachine.com writes:
See what's free at AOL.com.
PostPosted: Mon Jun 11, 2007 4:04 pm    Post subject: Air venting Reply with quote
Craig,
Yes, I have the factory NACA vents installed but cant get the airflow adjusted any higher than my chest. I just called Aircraft Spruce and ordered a pair of the plexiglass vents which I will install on the canopy sides so I can get cool outside air blowing right in my face. Thanks much for the information.
Tracy
PostPosted: Mon Jun 11, 2007 5:11 pm    Post subject: Air venting Reply with quote
Thank you for the compliment Bob.
It was a wonderful process, building from Zenith plans
and I really enjoyed it.
Larry
Bob Spudis
<http://www.aol.com?ncid=AOLAOF00020000000503>.
PostPosted: Tue Jun 12, 2007 9:03 am    Post subject: Air venting Reply with quote
My foggy memory thinks people used WD-40 with the hand-turned fly cutter to make the opening in the canopy. But this is second-hand.
Do your NACA vents lead to eyeball vents in the panel? If so you might try larger 2 inch eyeball vents:
http://www.steinair.com/eyeballvents.htm
http://www.creativair.com/aluminum-vent-p-98.html
http://www.aircraftspruce.com/catalog/appages/largealumav.php
-- Craig
[quote] [b]
amyvega2005(at)earthlink.
PostPosted: Tue Jun 12, 2007 10:40 am    Post subject: Air venting Reply with quote
eye ball vents are just not enough in the noon FLorida sun.
fderfler(at)gmail.com
PostPosted: Tue Jun 12, 2007 3:21 pm    Post subject: Air venting Reply with quote
But, the NACA vent blowing up your shorts is the best angle of attack indicator money can buy. I use it to judge climb speed/angle, to set cruise configuration, and to judge final approach. Why do you want it blowing on your chest? You are losing a valuable flight instrument!
Frank Derfler AMD-Built 601XL N183AM
See my information for pilots at www.flyinflorida.com [quote][b]
