Need a wiring diagram
dfultz7(at)earthlink.net
PostPosted: Sat Jun 09, 2007 10:30 am    Post subject: Need a wiring diagram Reply with quote
Does anyone have a wiring diagram for a Pointer 3000-11 Elt for the remote
switch. I bought a used one it came wired however there is two small wires
on at each end of the harness that were cut I need to find out if they need
connected together or connected to power and ground... Thanks Dale
wgill10(at)comcast.net
PostPosted: Sat Jun 09, 2007 11:04 am    Post subject: Need a wiring diagram Reply with quote
Dale,
Try this link: http://www.pointeravionics.com/manual.php
Bill
PostPosted: Sun Jun 10, 2007 6:15 pm    Post subject: Need a wiring diagram Reply with quote
Thanks Bill ,, I tried that route ,, you have to register to view the files
which I did but still haven't been able to access the file I need to view. I
am running out of time was trying to get done to make Oshkosh. Dale
PostPosted: Sun Jun 10, 2007 7:01 pm    Post subject: Need a wiring diagram Reply with quote
Hello Dale,
You have to register to view the Maintenance Manuals, but not the
Installation Manuals toward the bottom of the page. I attached the
Install Manual for the 3000-11 ELT remote switch from that site.
I had hoped to be done before OSH, but that's a huge stretch given the
current pace.
Bill
Pointer_2019-10%20Remote%20Switch%20DocREV3.pdf
 Filename:  Pointer_2019-10%20Remote%20Switch%20DocREV3.pdf
 Filesize:  74.57 KB
 Downloaded:  548 Time(s)
