fklein(at)orcasonline.com Guest
Posted: Fri Jun 08, 2007 5:21 pm Post subject: Spar guides? |
As I see the underside of the CM resting vertically on the floor w/ the
wings nicely mated and spar sockets in place, it occurs to me to
consider whether or not a couple of FG straps part way around the spars
might be useful to aid in the insertion of the wing spars during normal
rigging. Since I understand that the spar ends (between the two main
bolts/pip pin) I would think that such guide straps would want to be
held off the edges of the spar a nominal distance (1/8"?) in order not
to transmit in flight loads to portions of the CM not designed to take
them. .
I'm wondering if this is something others have done (?), whether it's a
good idea (?) or am I trying to address something which simply isn't a
problem (?) and just adding unnecessary weight and build-time?
Obsessing again,
Fred
A194
believed to be clean.
topglock(at)cox.net Guest
Posted: Sat Jun 09, 2007 7:32 am Post subject: Spar guides? |
Fred,
I'm going with your last paragraph. "...or am I trying to address something which simply isn't a problem (?) and just adding unnecessary weight and build-time?"
Jeff - Baby Blue
292 hours and almost time for the second annual...
P.S. Just a reminder. The end of August is drawing closer, everyday. Be sure to mark your calendars for the Europa flyin at Rough River KY. It's gonna be a blast! Anyone with questions, contact me or Paul McAllister for more info...
Fred Klein wrote: [quote]--> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com> (fklein(at)orcasonline.com)
As I see the underside of the CM resting vertically on the floor w/ the wings nicely mated and spar sockets in place, it occurs to me to consider whether or not a couple of FG straps part way around the spars might be useful to aid in the insertion of the wing spars during normal rigging. Since I understand that the spar ends (between the two main bolts/pip pin) I would think that such guide straps would want to be held off the edges of the spar a nominal distance (1/8"?) in order not to transmit in flight loads to portions of the CM not designed to take them. .
I'm wondering if this is something others have done (?), whether it's a good idea (?) or am I trying to address something which simply isn't a problem (?) and just adding unnecessary weight and build-time?
Obsessing again,
Fred
A194
