dale1rv6(at)comcast.net Guest
Posted: Fri Jun 08, 2007 6:47 am Post subject: Fuel Sending units |
Last month I had to remove float type sender due to gasket leak (after 850
hrs and 6 years). When I reinstalled the sender was inop. Quickly found the
electrical ground was bad. Cleaned the top screw holding sender to insure
ground; gauge was perfect again. Suggest you verify the ground contact.
Dale
