Posted: Sun Jun 03, 2007 11:29 pm Post subject: Nut plates also lock nuts? |
Here is an ignorant question: I'm playing around with nut plates for the
first time and notice that the screw does not easily thread all the way
through. The last few threads on the nut plate are
tight/distorted/out-of-round/something and it takes a little effort to turn
the screw all the way through. I've noticed this on a regular and a floating
nut plate. Is this done intentionally to provide a degree of locking?
-- Craig
NYTerminat(at)aol.com Guest
Posted: Mon Jun 04, 2007 3:33 am Post subject: Nut plates also lock nuts? |
Yes
In a message dated 6/4/2007 3:31:03 A.M. Eastern Daylight Time, craig(at)craigandjean.com writes:
| Quote: | Here is an ignorant question: I'm playing around with nut plates for the
-- Craig
See what's free at AOL.com.
dredmoody(at)cox.net Guest
Posted: Mon Jun 04, 2007 6:00 am Post subject: Nut plates also lock nuts? |
Yes. Nutplates are, in essence, high heat locknuts.
Dred
---- Craig Payne <craig(at)craigandjean.com> wrote:
-- Craig
grs-pms(at)comcast.net Guest
Posted: Mon Jun 04, 2007 1:58 pm Post subject: Nut plates also lock nuts? |
Yes.
George
richardharvey(at)nc.rr.co Guest
Posted: Mon Jun 04, 2007 5:02 pm Post subject: Nut plates also lock nuts? |
As you have already read, the bottom threads provide a very firm locking. I
couldn't even get a screw through without stripping the slot in the screw
head, so I ran a tap into each of the nut plates a little ways until they
loosened up enough to get the screw through. Be careful doing that however,
because if the tap goes in too far the nut plate gets too loose to be
secure.
Richard Harvey
601 XL 70% done
Jabiru 3300
Posted: Mon Jun 04, 2007 6:03 pm Post subject: Nut plates also lock nuts? |
To make it easier to screw the screws into the nutplates, use Boelube. That way you won't have to loosen the threads with a tap.
Dred
