Float geometry
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Seaplane-List
mail(at)hagenheckel.de
PostPosted: Sun Jun 03, 2007 11:46 pm    Post subject: Float geometry Reply with quote
Hi Joel,
in addition to Peter's infos:
Our regulations for UL's here in Germany (sould be similar with the FAA)
require the step to be 100 mm (4 inch) aft of the most aft C.G. and the prop
tip min. 300 mm (12 inch) above the water surface on MTOW.
Hagen
- The Matronics Seaplane-List Email Forum -
http://www.matronics.com/Navigator?Seaplane-List
peterc(at)pipcom.com
PostPosted: Tue Jun 05, 2007 4:10 am    Post subject: Float geometry Reply with quote
Hagen, that is a very interesting requirement about the distance of the step behind the cg. Haven't heard it before.
A fellow in Australia sent me an interesting article by Frey who was at Edo years ago. It brought out some concepts about step position. Will get this stuff together soon.
Peter
PostPosted: Tue Jun 05, 2007 10:04 am    Post subject: float geometry Reply with quote
Hagen, any chance you could get some background on the reasons for that step position. It is a little different from other rules I've heard.
Peter
Float Flyr
PostPosted: Tue Jun 05, 2007 10:22 am    Post subject: Float geometry Reply with quote
Hagen:
I take it the 4" for the step is also a minimum to help prevent porpoising on take off.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Jun 05, 2007 12:09 pm    Post subject: Float geometry Reply with quote
Noel, where have you been hiding? Haven't heard from you in a long time.
I've started to post some of my float geometry stuff. can link to it from:
http://www.pipcom.com/~cowcam/floatrig.htm
More to come. You may be upset because I'm not going to deal with your C of B calc method.
Peter
Float Flyr
PostPosted: Tue Jun 05, 2007 6:05 pm    Post subject: Float geometry Reply with quote
The CG method is just one method... nothing to get upset over. I was quite impressed with your practical approach on your web site. I'm interested in seeing your geometry calculations.
The CG 4" in front of the step is an interesting piece of legislation but I can see if it is a minimum how it would help keep a plane on step from rocking too much.
Property taxes then Insurance..... rain tomorrow... maybe I'll get it all straightened out then.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Thu Jun 07, 2007 8:08 am    Post subject: Float geometry Reply with quote
There is more material now on this subject. I'd appreciate any feedback/criticsm.
Peter
http://www.pipcom.com/~cowcam/floatgeo.htm
Float Flyr
PostPosted: Thu Jun 07, 2007 5:43 pm    Post subject: Float geometry Reply with quote
Nice lay out Peter. I never considered the height of the plane above the float to influence the position of the CG of the plane on the floats but you are right it does.
Keep it coming!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Thu Jun 07, 2007 7:35 pm    Post subject: Float geometry Reply with quote
Thanks Noel.
Peter
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Seaplane-List All times are GMT - 8 Hours
