582 cooling circuit pressure valve
Renaud
PostPosted: Wed May 30, 2007 10:29 pm    Post subject: 582 cooling circuit pressure valve Reply with quote
Maybe one of you have some experience about this: on my 582 (spak-plugs up, radiator at the bottom and expansion tank at the top), the excess pressure valve normaly integrated in the plug has been removed by the previous owner, apparently based on the recommendation of a "very experienced" guy (?!) As a result, the cooling circuit is never pressurized!?
This worked fine for about 75 hours, but I just discovered that now when applying full power, the water temperature suddenly drops very significantly, below the 140 °F limit. I don't remember this behavior when I started to use my plane last year.
I checked the liquid and the circuit: very clean, no corrosion, no obstruction. I am suspecting the absence of pressure valve, but I still can't understand why the temperature suddenly drops when applying full power.
Does one of you know the reason for pressurizing the cooling circuit: avoiding cavitation in the pump, increasing the boiling temperature of water, etc? Is there any risk of damaging the water pump when running unpressurized?
I forgot to mention that I have a cabin radiator in parrallel with the cooling radiator, but it is currently isolated with valve, so I don't think there is any impact.
Thanks for your help
Renaud
KitFox IV - 1200. Rotax 582.
Guy Buchanan
PostPosted: Thu May 31, 2007 7:01 am    Post subject: 582 cooling circuit pressure valve Reply with quote
Renaud,
You've got it right on both counts, though I seriously doubt
you can damage the water pump running unpressurized. The reason the
temperature usually drops below 140F is that the thermostat opens. I
usually see a 5-10F drop when that happens during warm-up. Be
careful, if your temperature is dropping rapidly from high to low due
to the thermostat opening you could experience "cold seizure", or
otherwise damage your pistons. If you're see a noticeable drop it may
mean your thermostat is not opening until a higher temperature and
then you're "quenching" the engine; not good.
I would look for the drop at 140 every time you warm up. If
you get a consistent rise past 150 I'd say your thermostat never
opened and should be replaced.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Renaud
PostPosted: Thu May 31, 2007 12:47 pm    Post subject: Re: 582 cooling circuit pressure valve Reply with quote
Guy,
Thanks for your quick reply! I have no thermostat!
I tried it today after manoeuvering the cabin radiator insulating valve and everything is fine now. No way to reproduce the problem... Maybe this valve was just stightly open and some cold water from the cabin radiator was pumped only with full RPM?!
However, I still don't understand the reason for having (or not having) a pressure valve at the expansion tank plug.
Based on all I read about "cold seizing", I will definitely install a thermostat.
Anyway, thanks again for your reply. Happy flying with Kitfox!
Renaud
Guy Buchanan
PostPosted: Thu May 31, 2007 8:31 pm    Post subject: 582 cooling circuit pressure valve Reply with quote
Glad to hear it worked out.
I guess you're talking about a pressure cap on the expansion tank.
The boiling point of the fluid increases with pressure. With a 15 psi
cap, (standard,) the boiling point of pure water increases 120F. I
don't know what the glycol mixture increases, but it might be the
same. The increased vapor pressure will also inhibit cavitation. Now
you might think that since we never go over 180F, who needs the
pressure? The answer is that you can get local hot spots in the water
jacket. If these boil the local heat transfer coefficient drops
dramatically, (vapor has a much lower heat transfer coefficient than
fluid,) and the hot spot can turn into a hole. (This was supposedly a
problem with the 912 and the reason they went to the Evans coolant.)
a thermostat.
No, No! You've got it backwards! Cold seizure generally happens with
a thermostat! If you don't have a thermostat it's harder to get "cold
seizure" but you can run the engine too cold, with the concomitant
poor performance.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Renaud
PostPosted: Fri Jun 01, 2007 2:07 pm    Post subject: Re: 582 cooling circuit pressure valve Reply with quote
Understood for the pressurized circuit. Thanks.
Regarding the thermostat, as I don't particularly need to improve the performance, I understand I don't need it. All I want is to avoid any kind of seizure. However, I am still a bit concerned about temperature falling below 140°F during descent or long approach. No risk of damage or seizure in these conditions?
Renaud
Guy Buchanan
PostPosted: Fri Jun 01, 2007 4:22 pm    Post subject: 582 cooling circuit pressure valve Reply with quote
Of course you can run the engine down to -20F and
it will run. After all, snowmobiles start from
this condition all the time. The problem comes
from doing any temperature change too fast.
Cooling is especially tricky, as the sleeves are
shrinking faster than the pistons, which can
ultimately cause damage. What's the max rate of
change? I have no idea! Maybe someone else can help.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Float Flyr
PostPosted: Mon Jun 04, 2007 4:04 am    Post subject: 582 cooling circuit pressure valve Reply with quote
Don't forget the higher up you go the lower the boiling point of water, or any liquid for that matter. That is why you can't get a boiled egg in the highest mountains...Don't even think of making a "good" cup of tea!! Without the pressure cap you will find the same thing that happens without it in a car. The engine will work pretty well until enough of the fluid boils off then the temperature will sky rocket! When I first got my 'Fox with the 582 the builder had plumbed it with the surge tank Teed into the return line to the engine. This of course vented the the cooling system to ambient pressure. Needless to say flights were very short before the coolant needed replenishment and you don't do that on a warm engine. The cooling system was re-plumbed with the surge tank on the low pressure side of the filler cap and now it works real well!
[img]cid:306105911(at)04062007-16A7[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  1023 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Roger Lee
PostPosted: Mon Jun 04, 2007 6:35 am    Post subject: Re: 582 cooling circuit pressure valve Reply with quote
Hi Renaud,
If you want a little higher temp and a more stable temp. Replace your coolant with some Evans NPG+. They claim you can run a no pressure cap, but Rotax recomends you still use the pressure cap. Evans is a waterless coolant that a lot of Rotax 912 owners use. Evans is used in lots of other applications like other planes, cars, motorcycles, ect... I have used it for 5 years and I'm happy with it. No water, no corrosion. It will raise the boiling point of your coolant from approx. 275F to 375F before it boils. It won't hurt anything. Try it and if you don't like it then go back to the 50/50 coolant. It's just something different. Some people like it and others have mixed opinions.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
rparigor(at)suffolk.lib.n
PostPosted: Mon Jun 04, 2007 9:52 am    Post subject: 582 cooling circuit pressure valve Reply with quote
"Evans NPG+. They claim you can run a no pressure cap"
This may be stated by Evans, but they expect you have the pressure cap on
the suction side of pump. I am not familiar with 582 system, but a 914 has
cap on high pressure side. On 914 will be running .9bar
Ron P.
Roger Lee
PostPosted: Mon Jun 04, 2007 1:06 pm    Post subject: Re: 582 cooling circuit pressure valve Reply with quote
Rotax still wants a pressure cap. 13 psi or .9 bar works well.
Roger Lee
Tucson, Az.
Cell 520-349-7056
Renaud
PostPosted: Tue Jun 05, 2007 1:27 pm    Post subject: Re: 582 cooling circuit pressure valve Reply with quote
Guys,
Thanks for your support. As soon as I can, I will make a test with a pressure cap from a friend. I just hope my rotary pump seal will not leak with pressure in the cooling circuit. Maybe the reason the previous owner removed it?
I was also thinking about adding a simple flap in front of the radiator to adjust the temperature during flight and limit cooling during descent. But the more complex system, the more risk of failure, mistake, etc... so I will probbaly give up this idea.
Renaud
Roger Lee
PostPosted: Tue Jun 05, 2007 1:44 pm    Post subject: Re: 582 cooling circuit pressure valve Reply with quote
Hi Renaud,
I don't think I would worry that much about your temp. It is not 140F all the time. It won't hurt anything.
Roger Lee
Tucson, Az.
Cell 520-349-7056
Guy Buchanan
PostPosted: Wed Jun 06, 2007 6:44 am    Post subject: 582 cooling circuit pressure valve Reply with quote
You may have already heard this. Go look at the radiator
louvers sold by HighwingLLC. They work and should the cable brake, fail open.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
