Corvair/Zenith engine mounts
naumuk(at)alltel.net
PostPosted: Wed May 30, 2007 2:53 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
Corvair people-
I'm to the point where I have to remove the short bolts already tack welded into the firewall engine mounts, and need to know the least destructive way of getting rid of the old ones. Do I have to beef up the existing parts, or should I even go so far as to make new ones?
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
ben_ramler2002(at)yahoo.c
PostPosted: Wed May 30, 2007 4:00 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
that to brings me to my next question in the 701's is anyone even running corvair? I'm sitting on a corvair engine and it would be nice to use it.
Ben
701 wanna-be
craig(at)craigandjean.com
PostPosted: Wed May 30, 2007 4:21 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
I have an unused set with the long bolts that you can have for free. Note that the upper mounts are the old style ones that are *not* integrated with the canopy attachment points. Picture attached. If you want them tell me where to send them.
-- Craig
 Filesize:  155.78 KB
 Viewed:  636 Time(s)
JerryHey
PostPosted: Wed May 30, 2007 4:23 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
Ben,   I believe the Corvair is a bit heavy for the 701.  Jerry  701 0% done.
On May 30, 2007, at 8:00 PM, Ben Ramler wrote:
[quote]that to brings me to my next question in the 701's is anyone even running corvair? I'm sitting on a corvair engine and it would be nice to use it.
Ben
701 wanna-be
PostPosted: Wed May 30, 2007 4:24 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
William Wynne is working on it. Look a little down from the top of this page:
http://www.flycorvair.com/hangar.html
-- Craig
PostPosted: Wed May 30, 2007 4:52 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
ok thank you Jerry at least that answers that question. What do you think would be a good alternative to the 912? maybe VW?
JerryHey
PostPosted: Wed May 30, 2007 5:38 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
Right now, I am looking at the direct drive VW with water cooled heads from Great Plains and/or I am also very attracted to an engine that does not yet exist which is the single rotor based on the Mazda rotary engine.   I will not install less than 100 hp since I have very short  (800 ft) grass field.  I like the Jabiru and Rotax but they are out of my league financially.  I like the Harley Hog engine too.  It looks cool and sounds great.    Jerry   701  0% done
On May 30, 2007, at 8:51 PM, Ben Ramler wrote:
[quote]ok thank you Jerry  at least that answers that question. What do you think would be a good alternative to the 912? maybe VW?---
rroberts
PostPosted: Thu May 31, 2007 3:20 am    Post subject: Re: Corvair/Zenith engine mounts Reply with quote
Guys,
HomebuiltHelp.com has a good video that may answer your questions: The "912" Competition. It covers the Sub, AeroVee, Corvair, Rotec, Jab, Suzuki, and Great Plains VW. Worth a look-see for sure!
Low & Slow
Rick
www.n701rr.com
www.ricksplace.info
gboothe5(at)comcast.net
PostPosted: Thu May 31, 2007 8:25 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
Ben,
Please note that you hi-jacked Bill’s “Subject” about engine mounts. Your questions will be lost in the List if you do not change your Subject, and Bill’s answers will be diluted by a different subject matter.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Ben Ramler
Sent: Wednesday, May 30, 2007 5:00 PM
Subject: Re: Zenith-List: Corvair/Zenith engine mounts
Ben
701 wanna-be
----- Original Message ----
Sent: Wednesday, May 30, 2007 5:49:11 PM
Subject: Corvair/Zenith engine mounts
Corvair people-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
PostPosted: Fri Jun 01, 2007 2:09 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
All-
As Sherlock Holmes would say, "Alternative plans are underfoot".
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
PostPosted: Fri Jun 01, 2007 3:43 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
No I don't think I did I asked about eninges and I don't see how "hijacked anything". they kind of apply to each other.
if your so concenerd how do I change it?
PostPosted: Fri Jun 01, 2007 4:00 pm    Post subject: Corvair/Zenith engine mounts Reply with quote
Ben,
The original question was about fitting the engine mount, not about running Corvair engines on a 701 (which is a very good subject all by itself).
When you hit the ‘REPLY’ button, merely tab down or click on ‘Subject’ and make a change. That way future listers can refer to the subject you intended, to get the information they are seeking.
I apologize if I seemed harsh. That was not my intent. My intent is to preserve the value of all this information as a future data base. You may not be aware that individuals can go to the Matronics site and do a “search” on any topic. Those topics need to be kept as pure as possible.
I wish you the best of luck in your future building endeavor.
Gary Boothe
Cool, CA
Sent: Friday, June 01, 2007 4:43 PM
Sent: Thursday, May 31, 2007 11:21:56 PM
Subject: RE: Corvair/Zenith engine mounts
Ben,
Gary Boothe
Cool, CA
Ben
701 wanna-be
Corvair people-
Bill Naumuk
HDS Fuse/Corvair
Townville , Pa
http://www.ma========================orums.matronics.com/" target=_blank rel=nofollow>http://forums.matronic===============
Be a better Globetrotter. [url=http://us.rd.yahoo.com/evt=48254/*http:/answers.yahoo.com/dir/_ylc=X3oDMTI5MGx2aThyBF9TAzIxMTU1MDAzNTIEX3MDMzk2NTQ1MTAzBHNlYwNCQUJwaWxsYXJfTklfMzYwBHNsawNQcm9kdWN0X3F1ZXN0aW9uX3BhZ2U-?link=list&sid=396545469]Get better travel answers [/url]from someone who knows.
Yahoo! Answers - Check it out.
