hills(at)sunflower.com Guest
Posted: Sat Feb 18, 2006 7:24 am Post subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS |
Howdy all;
I bought a 601hds a few months ago and have been flying it. I think I have
the wrong size propeller though, and I was hoping some of you might have
some advise as it is very slow and only climbs at about 600fpm.
The plane came with a New Great plains 2180cc engine, with 9:1 compression.
It should produce about 80 hp. It has a aerovee carb and fuel pump
regulated to psi.
The propeller is a Warniki 52x44 prop. On the ground it turns 3500 rpm. In
the air, it turns 3600 (or a little more), and you have to throttle back
quit a bit to see 3400 rpm. At 3400 rpm, it cruise at only 95mph, top speed
is less than 100.
I heard that these hds taper wing planes should go 120-140 mph, I dont have
wheel pants or gear fairings (its a tri-gear), but 95 seems very slow. I
think the prop might be too small, but everyone I ask tells me it needs a
different size. Some say a 62x42 (that sounds to big to me), great planes
says use a 60x29 (but a 29 pitch has a pitch speed of 90 mph, so I dont see
how it could make the plane go faster)
What do you all think?
Roger Hill
Posted: Sat Feb 18, 2006 9:27 am Post subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS |
Hi Roger,
There is a really neat prop calculator on the web at:
http://www.culverprops.com/pitchselection.htm
I would be glad to play with it to choose an exact prop for your
engine, but I don't know enough about your engine to do it. The
information needed includes the maximum RPM, whether or not you have
a PSRU (gearbox or direct drive) and what speed you think you can get
from the horsepower on your airplane.
I looked at Great Plains and could not find the information. The only
2180cc engine I found was a 70 HP direct drive version and I didn't
spend enough time to get the RPM red line.
I would suggest you play with the Culverprops calculator by inputting
your red line RPM, the correct reduction amount, and 150 or 160
MPH. Keep changing the prop length until you get something around
.80 mach for the tip speeds. This will give you the length to use
given the assumption (which may be totally wrong) that your engine
can produce enough horsepower to reach that speed.
From conversations I have had with other HDS owners, I suspect you
will not reach anything like that fast with a 70 HP engine. Those
speeds are the kind reached with a Jabiru 330 engine which produces
120 or 120 horsepower.
Another approach you can use is to install a variable pitch prop and
try different settings to get different performance. You will still
need to know your red line RPM to find a reasonable starting setting.
Good luck,
Paul
XL wings
| Quote: | Howdy all;
regulated to psi.
is less than 100.
Roger Hill
planejim(at)bellsouth.net Guest
Posted: Sat Feb 18, 2006 10:51 am Post subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS |
Roger & Linda,
I never operated a VW powered aircraft but I remember correctly, the KR1 and
KR2s had much faster cruise speeds. They had VW engines and were direct
drive. Large diameter props run into trouble on high rpm turning engines
without gear reduction. My Rotax 912UL of 80HP turns a GSC 66" dia. prop set
at 16degrees. I'm not sure what that converts to pitch in inches. TOO lazy
to figure it out. Of course the Rotax has a gear reduction of 2.27 to 1
which results in a prop RPM of 2335 when the engine is turning 5300 where I
cruise at. Probably could use a larger diameter prop but one has to watch
that the engine doesn't get overloaded. The airplane is at 100 to 105 MPH at
that setting. I do have wheel fairings. I haven't flown without them but I
would guess that the would make a 4 to 5 MPH difference.
You state that you have both low climb and low cruise. Usually it's a trade
off between them. I can really increase my climb but at cruise penalty or go
the other way and still have a respectable climb. Have to be carefull with
max RPM when I go toward the max. climb direction and too low RPM on
take-off if I go to the higher pitch. Comprimise - comprimise!.
Sounds like you just aren't getting the full power out of your engine to the
prop. This would possibly explain the low climb and low cruise.
You might talk to John or Jeremy Monnet about what prop they use on the
Sonex. They use a VW and cruise at the speed where the HDS is supposed to
go! Ask them about engine size ( they may be using bigger engines ) and prop
size matching.
Jim Hoak 601HD 500 hrs.
Larry McFarland
Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
Posted: Sat Feb 18, 2006 11:02 am Post subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS |
Roger,
The numbers you provide seem to be fairly accurate for the engine and
prop as applied to the 601.
I fly a Subaru that has a Warp Drive 70-inch ground adjustable prop.
With the prop set at 15-degrees,
the numbers were expected to be lower. 4500 rpm provided about 95-mph
and 5000 would get it to
110-mph. With the prop at 17-degrees, 4100 rpms get it to 105, 4650
gets about 120 and 5100 gets it
to 133-mph. The hds taper wings can go between 120 and 140-mph, but
most easily with the Corvair or the
Jabaru 3300 on board. The Subaru's a little slower, even with a good
spinner, wheel and gear box fairings.
I'd try the 60x29 prop, conditional to refund, to see if it would spin
up a little better. Is there no ground adjustable prop
for the 2180 engine? You'd be able to find the sweet spot a little
easier with one of those.
Larry McFarland - 601hds at www.macsmachine.com
Roger and Lina Hill wrote:
Howdy all;
regulated to psi.
is less than 100.
Roger Hill
_________________ Larry McFarland - 601HDS - Stratus |
n282rs(at)earthlink.net Guest
Posted: Sat Feb 18, 2006 1:16 pm Post subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS |
I had a 2180 with a redrive on my HD at one time. It was supposed to make
103 hp (at)4200 rpm. My max speed was 89 mph on a good day. Initial climb was
at least 1000 fpm, but after 5 minutes it would overheat. No way to cool
103 hp on those heads. I talked to a fellow in Indiana with a direct drive
in his. I think he said he as getting 90-95 mph. So your speeds are about
right. If you increase pitch for the higher cruise, you might get 5 mph
more out of it, but you are going to climb slower. You might also have
higher CHT's. If you want to go faster, you are going to have to change to
a different engine.
Randy Stout
n282rs"at"earthlink.net
www.geocities.com/r5t0ut21
| Quote: | [Original Message]
To: <zenith-list(at)matronics.com>
Date: 2/18/2006 9:30:19 AM
Subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS
<hills(at)sunflower.com>
Howdy all;
have
| Quote: | the wrong size propeller though, and I was hoping some of you might have
compression.
| Quote: | It should produce about 80 hp. It has a aerovee carb and fuel pump
regulated to psi.
In
| Quote: | the air, it turns 3600 (or a little more), and you have to throttle back
speed
| Quote: | is less than 100.
have
| Quote: | wheel pants or gear fairings (its a tri-gear), but 95 seems very slow. I
see
| Quote: | how it could make the plane go faster)
Roger Hill
rbutterfield(at)mebtel.ne Guest
Posted: Sat Feb 18, 2006 5:46 pm Post subject: VW PROPELLER SIZE ADVICE NEEDED- 601HDS |
At 10:22 AM 2/18/06, Roger and Lina Hill wrote:
| Quote: | I bought a 601hds a few months ago and have been flying it. I think I have
This I feel is your problem, specifically the diameter of the prop.
As a bit of an over-simplification, imagine the profile of the
propellor overlaid on the profile of the center section of the fuselage.
Props this size are successfully used on dimunitive planes like the
Hummelbird and the KR1. These little planes are only slightly over
20" wide, and quite low as well.
The 601, however, has a big chunky fuselage (at least by comparison).
As best as I can figure, it's cross sectional area is around 11 sq.
ft. The area of a 52" propellor disk is only 14.74 sq. ft. So, almost
75% of the propellor disk is blocked by the airplane. I think this is
a major reason for your relatively poor performance.
The William Wynne ZenVair uses a 66" Warp Drive prop with it's
Corvair engine. That propellor gives a disk area of 23.76 sq. ft.,
which leaves only 46% of it's area blocked by the airplane.
This is, of course, an over-simplification. A slippery,
well-streamlined airplane like the AR-5 http://www.ar-5.com/ can
use a proportionally smaller propellor than a boxy, draggy shape like
a Volksplane http://www.evansair.com/
RonB
