		rparigor(at)suffolk.lib.n Guest
		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Mon Jan 23, 2006 7:55 pm    Post subject: Pre-heating a Rotax? |
				Ron,
 I am using a Bob Reiff preheater.  It has a patch on the block and a band
 that goes around the oil tank.  The heater on the oil tank has a thermostat
 on it.  With what I know now I think I would have just bought a couple of
 heater pads from JC Whitney and made up a thermostat myself.  I would have
 cost me $90.00 instead of $200 some dollars.
 With that said, the Bob Reiff product does the job quite nicely.
 Paul
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		europa(at)triton.net Guest
				 Posted: Tue Jan 24, 2006 5:36 pm    Post subject: Pre-heating a Rotax? |
				Talked to Andy about winter operations the other day.  He suggested that the
 Rotax is built with tolerances similar to an automobile engine and therefore
 really doesn't need preheated.  After all, do you preheat your car?
 Also attended an aviation conference last week where it was suggested that
 pulling an engine thru scrapes the oil from the cylinders - so you're better
 off not doing that.  Also, heating the oil will drive moisture out and it
 deposits on the engine internals.  Bottom line, don't do anything to the
 engine.  Change the oil frequently (at least each quarter of the year).
 Jim Butcher
 N241BW
		raimo.toivio(at)rwm.fi Guest
				 Posted: Thu Jan 26, 2006 7:54 am    Post subject: Pre-heating a Rotax? |
				All (on the northern hemisphere)!
				 Posted: Fri Jan 27, 2006 2:21 am    Post subject: Pre-heating a Rotax? |
				Jeremy,
 OK - of course you are technically right but same target.
 When rich, catalytic converter cannot work as it should be.
 In fact, it is possible to spoil it by a little but possibe amount
 of rare petrol. And that is bad for your wallet and surrounding nature.
 If preheated I am sure also cc gets earlier upp to operating
 temperature and start to work sooner. When preheated,
 the engine idle time is usually shorter and that is good for cc.
 So, engine preheating also helps cc to save the world...
 Wishes, Raimo (not Teimo)
		paul.mcallister
				 Posted: Fri Jan 27, 2006 5:29 am    Post subject: Pre-heating a Rotax? |
				Guys,
 For what its worth,  I fly my aircraft in the winter in temperatures low as
 15f.  In addition to the engine heater I have a small electric blow heater
 that I have connected up to domestic air-conditioning/heater thermostat
 which keeps the cockpit at 50f.  The main reason is so that the gyroscopic
 instruments aren't being run at very cold temperatures, but is sure is nice
 to get into a warm cockpit as well.
 Paul
				 Posted: Mon Jan 30, 2006 7:39 am    Post subject: Pre-heating a Rotax? |
				Jemmy,
 my only statement was:
 What so ever engine preheating is always valuable
 and something what wise man should do if necessary.
 And it is necessary when cold enough and he has not
 heated garage...
 It is like preplay with woman. Some do it and some never.
 My honest recommendation - get happier life.
 Regards, Raimo
		Ivor Phillips
				 Posted: Thu Feb 09, 2006 3:01 am    Post subject: Pre-heating a Rotax? |
				It very similar to the kenlowe preheater i have been using on my Landrover
 for the last fifteen years, Works a treat, Certainly improves battery drain
 and starter motor wear!
 http://www.kenlowe.com/pre-heaters/cars/index.html
 Ivor Phillips
  	  | Quote: | 	 		   While talking to the local Rotax dealer, he suggested a heat exchanger
  instead of a thermostat and a separate oil cooler. On the attached (click
  link for list users) picture is also an engine pre-heater visible. the
  ribbed hose is the steel protected electrical cable. He promised me
  dimensions and weight data. The exchanger in the picture is a
  pre-production sample, the installation is on a 912 on an Eurostar.
				 Posted: Thu Feb 09, 2006 3:39 am    Post subject: Pre-heating a Rotax? |
				Yes, I have decided to go for separate water-oil heat exchanger
 with water thermostat and electric pre-heater.
 System will be tested in the test-bench before final installation.
 When stored in cold hangar, it can be always on.
 The cockpit /panel will be also (pre)heated and that is good for
 equipments. That is also what I have used to with cars.
 Cheers, Raimo
