What is the best size and location for Mod 70 access panel?
gcrowder2
PostPosted: Mon May 28, 2007 9:33 am    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
I still haven't done Mod 62 or 70 as everything seems tight and secure back there and at
220 lbs I really don't relish the thought of working inside the tailcone so I would like to add
an access panel that would facilitate these mods, as well as gain access to the elevator
trim mechanism. Could anyone recommend a size and location that might allow this?
I've seen some round panels that look helpful. I'm right handed so would it be best to
put the panel on the port side or would I need panels on both sides?
    Glenn
Add some color. Personalize your inbox with your favorite colors. Try it! [quote][b]
carl(at)flyers.freeserve.
PostPosted: Mon May 28, 2007 10:19 am    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
I dont believe it is possible to do mod 70 easily without crawling down the back of the tailplane (IMHO). If you arent able to get in there yourself (and I accept there are many who cant), then I would suggest you find a friendly midget who would be willing to assist (its amazing what kids will do for a bit of pocket money).
The standard inspection panel is about 6ins in diameter but by the time you make the flanges for the cover to fit against you only end up without about 5ins to put your arm through. Its ok for inspection but not for much else - and for you to hand the midget cups of coffee (and tools) to prevent them from falling asleep on the job.
I am pretty slim myself but correspondingly long in the body - I weigh 200lbs and 6' 2"". I managed the mod by crawling down the back but as most folks will testify it isnt an experience one wants to repeat.
Carl Pattinson
G-LABS
Dave Miller
PostPosted: Mon May 28, 2007 10:45 am    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
Glenn,
Adding access panels will not be an easy job, especially with all the re-inforcing work required.
Would be money well spent to find someone young enough and small enough to do the work, it does not take too long.
If you go into the back yourself, take a cell phone or have someone check regularly. I had visions of expiring there and being found a few days later.
Dave A061
"Carl Pattinson" <carl(at)flyers.freeserve.co.uk>
Sent by: owner-europa-list-server(at)matronics.com
05/28/2007 02:15 PM
Please respond to europa-list
To: <europa-list(at)matronics.com>
cc:
Subject: Re: What is the best size and location for Mod 70 access panel?
Carl Pattinson
G-LABS
kheindl(at)msn.com
PostPosted: Mon May 28, 2007 2:03 pm    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
Glenn,
You hit upon something I have been thinking about for a long time: a large
access panel right on top of the fuselage at the root of the fin, and
eliminating at least one of the other two mickey mouse openings, and giving
easy access to some very important components for future maintenance. Of
course the rim would have to be re-enforced in order not to weaken the
fuselage.
Isn't there a stress engineer around who could do the calculations and
design a mod for submission to the PFA ?
Karl
Reply-To: europa-list(at)matronics.com
Subject: What is the best size and location for Mod 70 access
panel?
Date: Mon, 28 May 2007 11:30:54 -0600
back there and at
I would like to add
the elevator
allow this?
would it be best to
Glenn
Create the ultimate e-mail address book. Import your contacts to Windows
Live Hotmail.
www.windowslive-hotmail.com/learnmore/managemail2.html?locale=en-us&ocid=TXT_TAGLM_HMWL_reten_impcont_0507
New, exclusive and FREE - Download Madonna's "Hey You" now!
http://www.liveearth.msn.com
jrgowing(at)bigpond.net.a
PostPosted: Mon May 28, 2007 2:05 pm    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
And after fiddling in the back 3 mths or ago, I still have a tingle in my right thigh where I had my groin across the sharp edge of the b.b. opening and stirred up the nerve in my leg.
I am not wanting to get back down there.
JR (bob) Gowing UK Kit 327 in Oz
DuaneFamly(at)aol.com
PostPosted: Mon May 28, 2007 4:10 pm    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
Glenn,
I just finished installing Mod 70. I don't know how I would have done the job without the two access holes in the tail on the starboard side (for my plane as I'm right handed). The forward most one is called for to be 4 inches in diameter. The inner ring for the screw plate brings this down to less than 3 1/2 inches and was very tight on my forearm. The rear "Viewing Hole" I have increased in size from 2.5 inches to four inches also. But this called for a lot of (4 plies of BID) re enforcing all around for about 4 inches out from the holes edge. I also added two more plies forward of the view hole to span the underside of the horizontal stabilizer's front edge. But when I did Mod 70, I had yet to add the inner ring for the screw plates to the viewing hole, so I had the entire 4 inch diameter to work with. My size precluded me from crawling far enough into the back to enable me to do the job....even though I have installed two cleats on the sidewalls just forward of the Mass Balance tower for a removable shelf that I could work on my elbows on. I also needed a drop light (car engine work light?) in the rear and set up a fan to blow cooling air through my front window (windscreen not yet installed), all to keep me from having a claustrophobic episode while working inside the tail. All this because the price of monkeys and skinny little kids has just gone through the roof in my area. A call or email to Europa might get you a little more info on any other possibilities or anything that you should not do. I hope this helps.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
See what's free at AOL.com.
fklein(at)orcasonline.com
PostPosted: Mon May 28, 2007 9:17 pm    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
Jeez I'm glad I don't have my top on!
DO NOT ARCHIVE
believed to be clean.
gregoryf.flyboy(at)comcas
PostPosted: Mon May 28, 2007 10:41 pm    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
Me either. What a breeze this mod is going to be! Smile
h&jeuropa
PostPosted: Tue May 29, 2007 4:05 am    Post subject: Re: What is the best size and location for Mod 70 access pan Reply with quote
I've spent a lot of time in the back since EFIS CPU was mounted there and to do Mod 70. What I found was that a cardboard box in the baggage bay the same height as the bottom of the D opening supported my stomach comfortably and kept the sharp edge of the opening from cutting. My legs ended up between the headrests.
Jim Butcher
N241BW
g-iani(at)ntlworld.com
PostPosted: Wed May 30, 2007 12:25 am    Post subject: What is the best size and location for Mod 70 access panel? Reply with quote
The attached drawing is of the "sled" which I use for access to the rear
of the Europa. Works very well and cost little to make.
I hope this helps
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
sled.pdf
 Filename:  sled.pdf
 Filesize:  24.72 KB
 Downloaded:  444 Time(s)
