My transition training experience
ddddsp1(at)juno.com
PostPosted: Fri May 25, 2007 11:20 pm    Post subject: My transition training experience Reply with quote
For those interested I posted a writeup on my TT with Mike Seager on
Vansairfoce.net under RV10 posts.
Dean 40449
Tim Olson
PostPosted: Sat May 26, 2007 4:45 am    Post subject: My transition training experience Reply with quote
Excellent write-up. I'd recommend it for reading by the group.
Perhaps you could post it here too?
Dean 40449
ddddsp1(at)juno.com
PostPosted: Sat May 26, 2007 5:35 am    Post subject: My transition training experience Reply with quote
Tim,
I would post it here but do not wanna resize the pics
smaller............too time consuming for my PC literate mind LOL
Dean 40449
orchidman
PostPosted: Mon May 28, 2007 5:18 pm    Post subject: Re: My transition training experience Reply with quote
Dean 40449
In your first posting at Vansairforce.net, you said 'I also noticed how much better qualilty the fiberglass Cabin tops are now vs the one we received.'
I will be ordering my Fuselage and finishing kits soon and was wondering if you could expand on how the quality has improved from when you received your top to what you saw there now?
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
ddddsp1(at)juno.com
PostPosted: Mon May 28, 2007 7:17 pm    Post subject: My transition training experience Reply with quote
Gary,
The tops are more uniform around the windows and door opening then
earlier models. Several areas needed to be built up to match the depth
around the doors and windows on early tops. Some tops even had VOIDS
in them that need to be refilled. It appeared if the mold had a bad
spot they just poured straight epoxy into the hole to fix it. I did
not see any of that on the ones in the factory now.
Dean
40449
