Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Sat May 26, 2007 6:43 pm Post subject: Climb rates at full gross |
Folks
I have the three blade MTV-12-B/193-93 prop mated to an I0-540-D4A5
Lycoming.
Question is, what climb rates are you getting at full gross. I'm about to do
my climb test and would like to know what to expect.
Ted French C-FXCS
RV-10 Flying with 13 hrs. Had to take a break due to a hernia operation....
_________________ Ted French
RV-10 fuselage |
Dsyvert(at)aol.com Guest
Posted: Sun May 27, 2007 2:37 am Post subject: Climb rates at full gross |
Tim,
Tim Olson just added as section called "Tim's RV-10 FAQ" that is located 3 lines below the picture of his plane on his home page. A lot of good info. I've copied below what he put in that section that I believe answers you question for his configuration. He has a Hartzell though.
How fast does it go, and how fast does it climb?The RV-10 has an approximate top speed of about 183-185kts if you equip it with a a standard 260Hp IO-540. Refer to Van's Aircraft for their official specs, but what is listed here might be a fair guide too. You can expect to cruise x/c at between 160 and 170kts. Climb while solo is about 2100-2200fpm, and climb with 2 front seaters should easily make 1700fpm. Loaded up full, you may see an anemic reduced climb of only 1500-1600fpm on a warm day. Even up at 10,000' MSL, your climb will likely approach 900-1000fpm. In short, yeah, it is plenty fast.
Dave Syvertson
Sugar Land, TX
40625
QB fuselage
do not archieve
See what's free at AOL.com.
