dashvii(at)hotmail.com Guest
Posted: Thu May 24, 2007 3:56 pm Post subject: Flight test results |
Well, after doing some preliminary work on my gap seal project I'm starting
to see some interesting results. After working out the data for the stall
speed tests I can report that 323AL stalled at exactly 44.2 knots with or
without gap seals in the clean configuration. This is as I predicted since
there's really no slot when the flaps are retracted. We couldn't do the
Flaps 30 b/c of how I designed the gap seals. Mine overlapped the flap and
would beat against it with flaps down. Sounded like a 727 thrust reverser
and we were uncomfortable as to what that might be doing to the airplane. I
can tell you that it should go up a couple of knots with flaps all the way
down. I can tell you that the cruise speed from Alpha Lima went up by
between 4-6 knots true airspeed at 2850 RPM. We ran at about 133 KTAS or
about 154 mph. Nick tells me that with a different prop and once they get
the jetting right with a prop it'll be a higher cruise speed. The max speed
is a little confusing to me. We got slower max speed during the gap seal
tests. I can tell you that for some reason the engine was turning about 200
rpm's less per data point than the unmodified condition. The temp was
warmer on the unmodified than the modified condition. I can't really
explain why the data come out like that. We got a max speed at 145 KTAS or
almost 170mph at about a 7,400 foot density altitude, but that was at only
3160 RPM's not the 3300 rpm that the engine is capable of with the right
prop pitch setup. Now on to the climb and glide stuff. Hopefully I'll see
something interesting there too. Enjoy, Brian W.
PC Magazine’s 2007 editors’ choice for best Web mail—award-winning Windows
Live Hotmail.
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
EAFerguson(at)AOL.COM Guest
Posted: Thu May 24, 2007 6:27 pm Post subject: Flight test results |
Brian - and everybody else,
Results sound great to me! I was concerned about the possibility of increased stall speed since I'm flying Light Sport, but that isn't a problem. If I can get +2 or 3K at 2750 it would be great, and I'll still be LSA legal. That might just eliminate one fuel stop on my coast to coast record run. It will surely increase my max range and give me more margin on the long legs.
So - - What do I have to do to be able to install the gap seals?
I will need to get a weight for the materials since I'm bumping the 500 kg limit now.
Earl Ferguson
N17EF
See what's free at AOL.com.
Posted: Fri May 25, 2007 5:45 am Post subject: Flight test results |
Earl,
There were two types of gap seals that I applied. The wider (6 inch?)
and the not so wide 2 inch duralar. I attached it simply by measuring the
gaps, then using carpet tape, available at any walmart. I then added speed
tape on top of that just to make sure that it stuck, but I think it would've
been fine without that. the widest strips went over the flaps and underside
of the aileron. The other went on the top of the ailerons and the bottom of
the elevator. I also had rub strips so that they wouldn't scuff the paint
on things like ailerons and elevator. I bet that you wouldn't add any more
than a pound, but I think that you'll just need to get the supplies together
and weigh it. We had to leave flaps up in our design, but if you took and
just covered the flap gap, leaving a small hole as to not touch the flap in
the raised position then I think you'd get the benefit plus the use of your
flaps. This is bound to do something for your fuel consumption, however we
did not test for that. The climb and glide should both go up, but I haven't
worked through all of that yet. When I do, I'll post the results. Faster
climbs mean that you get to altitude quicker and burn less fuel at altitude.
This sounds like it'd be perfect for your record attempt. Brian W.
Reply-To: lightning-list(at)matronics.com
Subject: Re: Flight test results
Date: Thu, 24 May 2007 22:27:05 EDT
problem. If I
That
limit now.
Earl Ferguson
N17EF
************************************** See what's free at
http://www.aol.com.
Live Hotmail.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
