Rivets
klr12(at)psu.edu
PostPosted: Thu May 24, 2007 4:13 am    Post subject: Rivets Reply with quote
Guys,
Can anybody tell me the length of the dash 5 rivets used in the spar? I
have been tasked with ordering them and my plans are at my son's house
200 mi. away.
Kevin
DaveG601XL
PostPosted: Thu May 24, 2007 4:24 am    Post subject: Re: Rivets Reply with quote
I have attached the rivet spec from Avex.
Good luck,
Avex Rivets Spec.pdf
 Filename:  Avex Rivets Spec.pdf
 Filesize:  33.9 KB
 Downloaded:  426 Time(s)
David Gallagher
Cincinnati, OH area
klr12(at)psu.edu
PostPosted: Thu May 24, 2007 5:33 am    Post subject: Rivets Reply with quote
Thanks Dave but I need the size of the solid AN470's used in the spar
caps. I've already got my Avex rivets but neglected to get the solid rivets.
Kevin
DaveG601XL
PostPosted: Thu May 24, 2007 6:18 am    Post subject: Re: Rivets Reply with quote
DUH! I should have read your note better.
Per the drawing 6-W-3 Dated 04/05, I see the following:
Spar Cap & Doubler (top and bottom) AN470-AD-6-14, 142 required
Top and bottom between stiffeners AN470-AD-5-9, 144 required
Top and bottom through hat stiffeners AN470-AD-5-10, 32 required
David Gallagher
Cincinnati, OH area
lwinger
PostPosted: Thu May 24, 2007 6:25 am    Post subject: Rivets Reply with quote
Kevin,
In the example of a rivet marked AN-470-AD-5-9, here is the code.
AN = Army Navy
470 = Head type
AD = Material type (in this case 2117 T4)
5 = Shank diameter in 32nds of an inch (in this case 5/32nds diameter)
9 = Length in 16ths of an inch (in this case 9/16ths length)
In the case of a 470 universal head, which we use, the length is measured from the end of the shank to the base of the head.
For the record, page 27 of the new Zenith Construction Standards manual (a very helpful document, by the way) has the length and diameter reversed in their example at the top of the page.
Larry Winger
Tustin, CA
601XL/Corvair
On 5/24/07, Kevin L. Rupert <klr12(at)psu.edu (klr12(at)psu.edu)> wrote: [quote]--> Zenith-List message posted by: "Kevin L. Rupert" <klr12(at)psu.edu
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
lwinger
PostPosted: Thu May 24, 2007 6:34 am    Post subject: Rivets Reply with quote
Kevin,
One last thing. Here is the link to the Aircraft Spruce online catalog page for solid rivets.
http://www.aircraftspruce.com/catalog/hapages/solidalumrivets.php
Larry Winger
Tustin, CA
Scratch building 601XL/Corvair
Control surfaces complete/2nd wing spar 80% done
Larry Winger
Tustin, CA
klr12(at)psu.edu
PostPosted: Thu May 24, 2007 7:15 am    Post subject: Rivets Reply with quote
Thanks All,
I have what I need and the rivets are ordered.
Kevin
planecrazydld(at)yahoo.co
PostPosted: Thu May 24, 2007 12:36 pm    Post subject: Rivets Reply with quote
Got a little couch potato?
Check out fun [url=http://us.rd.yahoo.com/evt=48248/*http://search.yahoo.com/search?fr=oni_on_mail&p=summer+activities+for+kids&cs=bz]summer activities for kids.[/url] [quote][b]
