john_rv10(at)yahoo.com Guest
Posted: Tue May 29, 2007 12:43 am Post subject: Advanced Flight Systems firmware upgrade problem |
Hi All,
We recently purchased an RV 7 with an ACS 2002 engine monitor. It had v3.0.0
A04 firmware on it, and we updated it with the most recent version, 3.2.2
When we started it after the upgrade we had lost reference to CHTs for
cylinders 1 and 4
Has anybody else had the same experience? If so, how did you fix it?
Thank you,
John Cleary
| - The Matronics Avionics-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
mlas(at)cox.net Guest
Posted: Tue May 29, 2007 6:32 am Post subject: Advanced Flight Systems firmware upgrade problem |
John,
I have not had that problem, as a matter of fact the only problem I have
ever had with the AC2002 (now know as AC2500) is when you short a sensor
you loose the other sensors that have the same power supply driver. I
have installed over a dozen of these unites over the years and I have
one in my plane. The Best solution is to call the boy over at Advanced
Flight, they will work through the problem with you directly. I have
always thought their tech. support as being one of the best.
Posted: Tue May 29, 2007 10:52 am Post subject: Advanced Flight Systems firmware upgrade problem |
Thanks Mike
Posted: Tue May 29, 2007 12:28 pm Post subject: Advanced Flight Systems firmware upgrade problem |
For anybody else caught with this it seems the fix is simple. When the
firmware upgrade is initialized, the unit automatically sets itself up for a
Rotax engine. You just need to go to calibration mode and tell the unit it
has 4 cylinders to monitor.
The steps to follow are:-
Go to the calibration menu (hold button 4 down on power up)
Select 10. CHT from the menu
Set Item 12. Instrument ON/OFF to ON
Set Item 13. Number of Cylinders to 4.
Press the return button 2 or 3 times to return to the main screen.
