VE3LVO(at)rac.ca Guest
Posted: Mon May 21, 2007 6:08 am Post subject: Trailer caution |
Yesterday, a buddy and I went to the airport and recovered the
Europa wings on the trailer, from the hangar. The intent was to match same
to fuselage for purposes of rationalising feed-through sites for wiring and
odd items. By the way, these and the other surfaces were beautifully
finished by a local firm to a tough mirror finish.
All was normal on the 30-minute trek back home, and we unloaded same
onto brackets built to set them vertically (nose-down) prior to installing
them. When we began the sequence, I noticed a discolouration on the port
leading edge and discovered a smashed leading edge about two inches in
diameter, right on the leading edge - right down into the blue foam.
This corresponded to the position of the wing in the rubber strap
(lined with bubble-wrap). I noted that the pip-pin for the strap structure
hinge release sits dead-centre under the strap. Sure enough the strap was
pure (?) rubber and I could stretch it downward with just my fist. There is
no question that, given the odd bump neatly handled by the trailer, evolved
into a surge of the wing down until the pip-pin punctured the wing.
This is going to lead to at least a week's delay, in rebuilding the
wing and then driving it about 70 miles on country roads to the now-retired
re-finisher. He took the tools/fixtures with him to his home airport.
So this is a belated warning:
(a) reposition the clamp-folding pip-pin to another suitable site away from
the wing leading edge, and
(b) replace the rubbery slings with some (preferably white) rubber with
cloth reinforcement to resist excess stretching. I'm still going to line
same with bubble wrap as I have saved acres of it and it works.
I will be canvassing McMaster-Carr and similar sources for same. If
you are light years ahead of me and already possess same, please advise.
All advice gratefully accepted.......
Ferg Kyle
Classic mono 914 (ten years on 24 May)
josok-e(at)ukolo.fi Guest
Posted: Mon May 21, 2007 7:19 am Post subject: Trailer caution |
Hi Ferg,
Sorry about your mishap. I might add my adventure here:
The trailer i have has woven strings, from a material as used by lorries
as strap-down.
On my way to the painter i noticed in the mirror that a wing was moving
around more then i would expect, so i stopped a few miles down the road.
Then became clear that both wings had moved backward, and that there was
only 2 inches of spar left in the clamps. It would not have taken very
long anymore before a wing went flying! The wind force on the fairing,
together with bouncing in the straps had been more then the friction of
the otherwise tight clamps. Securing both spars with a rope around the
aileron mechanism is really needed!
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
Posted: Mon May 21, 2007 11:51 am Post subject: Trailer caution |
Hi! Ferg
Sorry to hear of your misfortune, you must be "gutted". Just for the
record my wing carriers are made of spent conveyor belting lined with
carpet attached by heavy duty upholstery glue. I don't tie the wings
down but the carriers are about 12"/15" wide thereby spreading the load.
However since my trailor weighs in, loaded, at about 3 tonnes and has a
double axle linked weight transfer suspension nowt bounces! I do think
though that to spread the load is very relevant since it reduces the psi
point loading on the wing.
They are also fixed laterally by the pip pins through the spar holes.
Bob Harrison G-PTAG
jrgowing(at)bigpond.net.a Guest
Posted: Mon May 21, 2007 2:04 pm Post subject: Trailer caution |
Ferg,
I am sure the Europa community feels for you in your misery over the crunced
in leading edge.
None would like the same misfortune
Best Wishes for a good recovery which I hope will be easier than you now
think.
JR (Bob) Gowing UK kit 327 in Oz
Posted: Tue May 22, 2007 12:31 pm Post subject: Trailer caution |
Just a quick note to those who kindly replied to my message about the punched wing leading edge - Thank you. It's always an advantage to hear from others and get the true word.
This is first time I've used this form of reply so hope it works
Ferg A064
Visit - www.EuropaOwners.org
erichdtrombley(at)juno.co Guest
Posted: Tue May 22, 2007 1:54 pm Post subject: Trailer caution |
Ferg,
I had the same happen to me last year, only I have the foam inserts not the rubber sling. On a long haul from the airport to the house (at night) I was unaware that the foam had split allowing the wing to slide down and make contact. Very frustrating. Mine wings had been painted for two years, however, I had been fortunate up to that point in that the paint was in pristine condition. So, I definitely feel your pain. I have since made a new wing support for the trailer which is 12" wide, thus spreading out the load. Good luck
Erich Trombley"
N28ET Classic Mono 914
Subject: Europa-List: Trailer caution
Ferg Kyle
Rschultz5(at)houston.rr.c Guest
Posted: Tue May 22, 2007 8:04 pm Post subject: Trailer caution |
The link below will give you some photos of a wing support and holder that I have used. I have used it several times to carry the aircraft in excess of 1000 miles without so much as a hint of damage. I work in the oil and gas industry we do a lot of work with vibration dampening. I asked the guys that run the shake tables about a design to prevent road damage to my wing and reduce stress on both the leading edge and spar. The outcome was a firm blocking system clamping down on the spar with the bell cranks tight up against and additionally a bungee cord holding the aileron bell crank to the hold down. The wing tip is supported by two layers of floor carpet. The first layer is held in place with a metal clamp attached to another bungee cord running over a boat roller and designed to support and hold the wing. A second layer of carpet is placed loose over the first and a plastic bin liner is added to the wing skin to prevent the carpet from scratching the paint. It ends up that the carpet fibers are a really great vibration damper. I use the 3m Blue painters tape to hold the plastic liner in place and also to wrap around the flap hinges to prevent the flaps from moving or bouncing up and down.
http://home.houston.rr.com/n262ae/trailer.htm
Rich Schultz
N262AE
122 hours and the most fun I have ever had.
Dave Miller
Posted: Wed May 23, 2007 4:42 am Post subject: Trailer caution |
Ferg,
Hope the repair goes well.
There are "Colorworks" franchisees in Burlington and Oakville. These people do repair work for the auto dealerships, fixing small dings, dents, scrapes, blemishes etc.
They have mobile vans with the paint equipment, and can match colour and airspray the damaged area.
May be the easiest way of getting the paintwork re-done.
Dave
"Ferg Kyle" <VE3LVO(at)rac.ca>
Sent by: owner-europa-list-server(at)matronics.com
05/22/2007 04:27 PM
Please respond to europa-list
cc:
Subject: Re: Trailer caution
--> Europa-List message posted by: "Ferg Kyle" <VE3LVO(at)rac.ca>
Ferg A064
