Rotax 582 failure (semi off-topic)
Michel
PostPosted: Thu May 17, 2007 12:19 pm    Post subject: Rotax 582 failure (semi off-topic) Reply with quote
Gentlemen, this is not Kitfox business but since many of us fly behind
a 582, I wonder if you could have a look at this.
My friend flying an Avid Flyer lost his 582 in flight, as I said
earlier. His engine is old, from 1990, it has a total of 340 hours but
it has been serviced in 2002, including new crankshaft bearing, when
the engine had 280 hours.
Inspection of the engine by a Rotax mechanic shows that the aft
cylinder conrod roller bearing was completely destroyed. The conrod was
loosen from the crankshaft and the sump showed several cracks. The
forward cylinder and conrod showed no damage and everything else was
moving and well oiled. Here is a photo of the opened engine. Has anyone
an idea of what could have gone wrong because the Norwegian mechanic
has not a clue. Thanks in advance.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
 Filesize:  78.66 KB
 Viewed:  615 Time(s)
Bob
PostPosted: Sat May 19, 2007 1:52 am    Post subject: Re: Rotax 582 failure (semi off-topic) Reply with quote
Michel -
The "classic" signs for typical bearing failures are pretty easy to find through a Google search, but it's easy to get mis-led, kind of like trying to use the web to diagnose a medical condition. I've looked at many failed bearings and it takes personally looking at it closely under magnification. You might see if you have degreed mechanical or metallurgical engineers in your area to ask.
Bob
Remember that internet advice may only be worth what you pay.
occom
PostPosted: Sat May 19, 2007 2:31 am    Post subject: Rotax 582 failure (semi off-topic) Reply with quote
It's hard to tell from the photo. It looks like there is a small spot of
rust on the crankshaft web in that cylinder. (Seen just above the arrow) If
that cylinder was open for an extended period of non running and had not
been properly sealed and lubed for storage it's likely that moisture also
got to the bearings. They just will not last with rust pitting.
It's too bad the fellow had not had the crank replaced when the engine was
service close to the overhaul point of 300 hours.
Dave Goddard- Mod IV 1050/582
Michel
PostPosted: Sun May 20, 2007 10:34 am    Post subject: Rotax 582 failure (semi off-topic) Reply with quote
thank you Bob and Dave for your answers. I have forwarded them to the
owner of the engine.
Michel Verheughe
Norway
Kitfox3 - Jabiru 2200
gofalke(at)sbcglobal.net
PostPosted: Sun May 20, 2007 6:17 pm    Post subject: Rotax 582 failure (semi off-topic) Reply with quote
Michel
PostPosted: Tue May 22, 2007 10:16 pm    Post subject: Rotax 582 failure (semi off-topic) Reply with quote
If somebody is interested, here are the close views of the 582 that
went amok.
http://rolf.nossum.net/582.broken.rod/
Michel Verheughe
Norway
akflyer
PostPosted: Wed May 23, 2007 6:23 am    Post subject: Re: Rotax 582 failure (semi off-topic) Reply with quote
I have seen this quite a bit on snowmachines.. in fact had one almost identical two years ago on my AC 600. From the enlarged pics it looks like the piston siezed first and it twisted off the conrod. I have lost conrod bearings before and it will get to slapping and knocking, but that twisted conrod leads me to beleive the piston was the culprit. See if you can find out if the scuffing on the piston was on the intake or exhaust side.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Michel
PostPosted: Wed May 30, 2007 1:18 pm    Post subject: Rotax 582 failure (semi off-topic) Reply with quote
Sorry for the delay, I was taken by other matters. Thank you Leonard, I
will forward this to the owner.
Michel Verheughe
Norway
Kitfox 3 Jabiru 2200
