Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Thu May 17, 2007 8:18 am Post subject: KitFox wheel base? |
Gents...first, I want to thank all the fellas who responded to my earlier questions on the wings. Absolutely wonderful data!
Next question is...what is the length of a Kitfox between the mains and the tail wheel?
IN other words, how long of a trailer deck is needed to haul a KitFox Series IV speedster?
Also, is it recommended to trailer a KitFox with the tail weight sitting on the tail wheel when folded?
for 500 miles?
or is there some other method of supporting the wings?
OR supporting the rear of the fuse?
Will the front attachment fitting on the wings take this also?
Thx in advance !
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Lynn Matteson
Posted: Thu May 17, 2007 9:57 am Post subject: KitFox wheel base? |
I hauled my very much incomplete 'fox 1300 miles on a converted boat
trailer (2-leaf springs on the trailer). The trailer was for a light
boat of the fishing variety, not a speedboat for the whole family.
The ride for the plane should be smooth. With the wings folded, there
will be too much weight on the rear wheel. There is a cross-tube near
the rear wheel, that is used for a support of some fashion, and it
keeps the weight off the rear wheel while it is on the trailer. I did
not know this at the time I did my big haul back here. It is best, I
believe, to elevate the fuse so it rides somewhat level. My wings
rode on the trailer alongside the fuselage, cushioned with foam. I
hauled my plane from Texas to Michigan with just the weight of the
fuselage on the tailwheel, as I said, no wings, no tailfeathers, and
my tailwheel spring eventually broke after a few months of flying it.
I don't know whether the 1300-mile ride caused that breakage or not,
but it couldn't have helped the situation.
You should see about making, or buying from John McBean, a set of the
front wing spar supports.
Lynn Matteson
flying w/275+ hrs
On May 17, 2007, at 12:18 PM, Don G wrote:
and the tail wheel?
for 500 miles?
Thx in advance !
Don G.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
jezim(at)pro-ns.net Guest
Posted: Thu May 17, 2007 11:24 am Post subject: KitFox wheel base? |
| Quote: | From the center of the tailwheel axel to the center of the main axel is 14
feet on my series 5 with spring gear.
Jim Zimmerman
Stillwater MN.
Under construction. 0-200
john(at)leptron.com Guest
Posted: Thu May 17, 2007 12:31 pm Post subject: KitFox wheel base? |
Don,
I have trailered my speedster on a 14 foot dual axel snowmobile trailer nose
first several thousand miles. I would rather tow tail first but on 14 foot,
you have to put prop over the tongue. Duel axel is best for chuck hole
support the lighter the spring system is the better 500 miles is no big deal
just watch for the big holes and ledges. Make sure there is no fuel on board
and use the wing outer spar braces. If you intend to tow a lot, I would make
a support for the tail tow inserts. I did see one fox break in front of the
tail, but that is one out of how many?
John Oakley
Don G
Posted: Thu May 17, 2007 1:33 pm Post subject: Re: KitFox wheel base? |
I dont plan to haul it ever again, If I buy it, it will live in a nice cushy hangar.
I have a 16ft tandem flatbed utility...7000 gvw...about 1200 empty and I am aware that this is sprung a tad stiff for airplane duty. But so far, it might be my only choice. I have lots of tractor weights I might add to ease the ride. Dunno yet.
I now see that at least it will fit on the deck....barely.
I am looking for a better option still.
What are these wing supports and how do they work? Do they attach to the airframe?
I have seen mention of removeing the wings entirely and stowing them. Will they fit in the length under the plane between the mains and the tailwheel?
Ailerons would probably need to come off to do this?
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Lynn Matteson
Posted: Thu May 17, 2007 2:33 pm Post subject: KitFox wheel base? |
Maybe lower the tire pressure on the plane to practically nothing,
support the tailwheel on old sofa cushions or an old overstuffed
chair. You might look like the Beverly Hillbillies, but who cares?
The wing supports go from the attach point of the wing's front spar
down to one of the tabs on the fuselage. You can build them as crude
as you'd like for a "one-shot" deal, maybe even hammering out the
ends of pipe, instead of welding in a nice tab. I'm sending you a
picture of mine on separate mailing.
Lynn Matteson
flying w/275+ hrs
On May 17, 2007, at 5:33 PM, Don G wrote:
nice cushy hangar.
to the airframe?
and the tailwheel?
Don G.
N369LM |
Posted: Thu May 17, 2007 3:47 pm Post subject: KitFox wheel base? |
Don,
How soon are you going to move the plane?
John O
Don G
Posted: Thu May 17, 2007 5:22 pm Post subject: Re: KitFox wheel base? |
Thx for the pics...I understand perfectly now.
As far as the Move..The Deal has not been struck yet. I have an offer to trade and we not very far apart on the money. The biggest Holdup is the move. IF we were not 525 miles apart, I think we would have come together probably. Right now...I am at the point where I have to decide if all the trouble is worth it.
My Kolb FireFly will not make the flight. It is just not a crosscountry machine.
The KitFox is out of annual...etc...etc....
So I am exploring all the details...then must decide to kick in a little more boot...
Trouble is...you guys have about got me talked into the notion that the Speedster is just what I want!!!!!!! (grin.......
If we come together...the move could be a soon as a week...or maybe a month. I havent asked about storage after the purchase.
What have you on your mind John?
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Posted: Thu May 17, 2007 7:09 pm Post subject: KitFox wheel base? |
Don,
Just to save you time, if and when you go to move I will loan you my braces.
I can stick them in a tube and mail, or FedEx, you can return the same way.
john
Don G
Posted: Fri May 18, 2007 3:29 am Post subject: Re: KitFox wheel base? |
John,
Thank you so very much for the offer.
Lynn sent me the pics of the braces, and I think I could fabricate them pretty quickly though. I have all the materilas on hand and a really good shop.
Seems I could make them telescoping and just drill one side of the center so I could adjust them on site for length on the plane and then drill the other side using 1st hole to locate.
This probably wont take as long as building braces for the rear of the fuse on the trailer and maybe some sides...some thing to hold the wings...arghh.. Today I am going to search for an 24 ft enclosed trailer to rent..borrow...I would much rather sling the wings in an enclosed trailer.
Getting the Kolb trailered down there is about as much of a problem to figure out.
Anybody know anything about N85KF...Yellow with red trim, built by Solomon Bradman ...florida address????
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
av8rps(at)tznet.com Guest
Posted: Fri May 18, 2007 6:11 am Post subject: KitFox wheel base? |
Don,
After doing a lot of trailering of Avid Flyers and Kitfoxes over the years,
I think Lynn's comments were right on. But a few I would like to add;
- If trailering with the plane backwards on an open trailer (the way the
Avid & Kitfox factories made their trailers) make absolutely sure to support
the rudder and elevator with carpet covered boards. If a gust of wind from
a truck going by catches those tailfeathers they will be seriously damaged.
I found on my Model IV with the tall rudder going accross Iowa in some gusty
winds on the trailer that I had to remove the rudder altogether as even the
boards weren't working.
- Definitely support the lower rear fuselage. Even if you can just split
the load from teh tailwheel to the lower fusealage you will do better than
just resting it on it's tailwheel. If only on the tailwheel, the airplane
will move up and down on the tail spring too much, which also works against
any other attaching ropes or hardware you might have hooked to the airframe
elsewhere.
- Add additional ropes for safety to the wings (besides the wing to
fusealage attaching rods). I usually just run a rope from the wing struts
of each wing to the other wing strut, and tie it to the fuselage lift
handle. If one of those wing attach rods came undone going down the road
without this safety rope, the wing will swing out and catch the next light
pole or truck. A friend of mine had this happen on the way to the airport
with his airplane, ready for it's first flight. When the wing hit the
lightpole, it ripped the airplane right off the trailer. It was a complete
loss.
- MOST DEFINITELY USE THE FRONT WING SPAR ATTACH RODS AND REMOVE ALL THE
FUEL FROM THE TANKS (so as to alleviate all the excess weight from the wing
in the folded position - plus if you don't it will probably run out anyhow).
If you don't do this, you stand a good chance of twisting or damaging the
rear spar and/or the attach fittings/tubes. Not worth taking a chance like
that.
- Speedsters have less dihedral, and more flapperon counterweights than
normal model IV's. That sometimes makes folding the wings back more
critical as the flapperons leading edges will almost rest against the top of
the inboard horizontal stabilizer. So make sure you use the braces that
hold the wings folded so they move the least amount possible, and make sure
to pad the fabric where the flapperon is close or rests on the stabilizer.
Also, check to make sure the inboard flapperon counterweights aren't resting
against the fusealage fabric near the turtledeck. My airplane had all these
issues, making it much more difficult to trailer than an early Avid or
Kitfox.
- Pad your vertical fin where the flapperons get close to it during the wing
fold. The flapperons on a model IV are disconnected, so the only thing
holding them up is the vertical fin and rudder. You don't want to get home
to find you need to do fabric repair where the flapperon trailing edge
rubbed through the fin fabric.
- Strap down the wheels and the gear so the airplane doesn't bounce should
you hit a large pothole or crack in the road.
- Make sure the ELT is disabled/off. I heard of a guy that trailered a
Kitfox halfway across the country in an enclosed trailer, having the Civil
Air Patrol chasing him the entire way. (at least it proved that an elt
antenna will work with an inside the fueselage antenna...)
- Use a trailer with the lightest springs you can find, or as you said, load
the trailer accordingly to reduce the "jolt effect" to the airframe.
- You will need to seal up the cabin and turtledeck area so rain won't get
in when traveling. DON'T USE DUCT TAPE TO HOLD THE PLASTIC ON. It will pull
off paint from the fabric. I learned this one the hard way.
I know this might sound like a lot of BS, but if you keep this note handy
when putting it on the trailer, it will all make sense.
If you decide to use an enclosed trailer or truck, a kitfox will fit nicely
inside a u-haul truck if you remove one wing. A covered trailer or truck is
always nicer in my opinion, but not always as cheap or available. Either way
works, but the open trailer is generally more labor intensive.
And here's a little Avid/Kitfox trivia - The first Avid flyer was trailered
to and from Oshkosh 1983 on it's own wheels with just a tow bar. No trailer
required! They didn't use a trailer until they put it on floats the next
year. Oh yeah, they still opted to pull it tail first.
Float Flyr
Posted: Sat May 19, 2007 5:46 pm Post subject: KitFox wheel base? |
I only trailered my plane once on the donuts. I took this picture when I was still figuring out all the complexities of how to strap the plane to the trailer.
The trailer itself is a single axel double snowmobile trailer which has been home modified with a seven foot extension to the tow bar which has a channel installed on the top of it for the tail wheel to roll in while loading and to support a vertical stand, not in the photo, which fits under the mounting nut for the tail wheel spring. The tail wheel spring is then tied to the rear corners of the trailer platform and down and forward to the hand winch. Tied fairly tight three ways it cannot move!
The main deck of the trailer has wheel blocks bolted right through the deck that positions the aircraft and works to trap the main gear against the loading ramps (2) which fold back and are tied to trap the main gear. The aircraft is positioned so the CG is roughly right over the trailer wheels with the wings folded.
Using this system it only takes about ten minutes to load and tie down the plane. The trick is to open the wings before starting to load and to manually put the tail wheel up on the trailer where the tail wheel can be attached to the hand winch which will pull the plane aboard the trailer. Then trap the main gear with the ramps (heavy hinges welded to deck of trailer for ramps) and tie the ramps in the up position. Lift the tail and insert the support under the tail spring, tighten the winch slightly and then install two guy ties which will go from the tail spring to the corners of the trailer deck. Load the turtle deck and gas in the car and you're ready to go!
One modification I was considering was a box bolted to the deck to carry gas cans for the plane. I use "ratchet" style tie downs for the main gear traps and the tail "guy ties". Four ties does the whole thing.
One other quick note about trailering the plane back on.... always tie the wings closed as well as use the closure supports that attach to the base of the vertical stab. Having one of those little clips come off on the highway is not an option! Always use an elevator lock when towing too.
[img]cid:310002801(at)20052007-0212[/img]
[img]cid:310002801(at)20052007-020B[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
19.77 KB |
528 Time(s) |
88.4 KB |
577 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
