Need help on elevator
hansriet
PostPosted: Wed May 16, 2007 11:19 am    Post subject: Need help on elevator Reply with quote
Friends,
I'm making good progress on my 601 (XL) tail section.
I'm now at the stage to make the cut-out for the elevator horn doubler.
I drilled the 3 stress relief holes, but I see no way to cut out the triangle with snips. (At least not without destroying the skin).
Has anyone a better method than that described in the building plans?
Hans
DaveG601XL
PostPosted: Wed May 16, 2007 11:38 am    Post subject: Re: Need help on elevator Reply with quote
Drill a hole in the middle of the intended cut-out big enough to get your tin snips in. Cut a hole from the center to each corner hole. Use a shop or Olfa knife and score a line between each corner hole. Use pliers and bend next to the score lines back and forth until they break-off. You will have a neat triangle cut-out. Use can use this scoring method of cutting aluminum in other areas to get straight cuts. Just be careful with your scoring so the knife does not slip. Practice this method on a piece of scrap first before doing it on the real thing.
Good Luck!
David Gallagher
Cincinnati, OH area
Michael Valentine
PostPosted: Wed May 16, 2007 11:46 am    Post subject: Need help on elevator Reply with quote
I don't recall what was described in the plans. For this kind of odd shape (or where pieces were too thick) I drilled a bunch of holes next to each other and then just broke it off. YOu should also pick up a nibbler if you don't have one - it is extremely handy for snipping in small spaces.
Michael in NH
On 5/16/07, hansriet <hansinla(at)mac.com (hansinla(at)mac.com)> wrote:[quote] --> Zenith-List message posted by: "hansriet" <hansinla(at)mac.com (hansinla(at)mac.com)>
Friends,
Hans
paulried(at)rogers.com
PostPosted: Wed May 16, 2007 12:04 pm    Post subject: Need help on elevator Reply with quote
Hans:
I used a unibit and drilled until I got close to the edges and then hand
filed the rest.
Paul Riedlinger
slook(at)mchsi.com
PostPosted: Wed May 16, 2007 1:59 pm    Post subject: Need help on elevator Reply with quote
I don't remember if I drilled a hole big enough to use a nibbler tool
in or if I used the Dremel with a cut-off disk. It was one of those
methods. That's pretty much how I do all the tight cuts.
Steve
Steve Look
Monticello, IL
601XL, Corvair
"Dogs have owners, Cats have staff"
naumuk(at)alltel.net
PostPosted: Wed May 16, 2007 2:53 pm    Post subject: Need help on elevator Reply with quote
Hans-
Put a strip of duct tape on both sides of your line, leaving enough room
for the thickness of a sabre saw blade. Then, use a blade suitable for
aluminum to cut the opening. That's how I accomplished the cuts in the
attached picture.
Good building!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
 Filesize:  38.12 KB
 Viewed:  540 Time(s)
dgardea(at)gmail.com
PostPosted: Wed May 16, 2007 5:08 pm    Post subject: Re: Need help on elevator Reply with quote
I used my dremel (see the attached pic) to cut fairly close to the line and then filed the rest straight and smooth. Get a good grip on the dremel just in case the wheel bites should you go too fast.
 Filesize:  66.29 KB
 Viewed:  550 Time(s)
Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html
hansriet
PostPosted: Wed May 16, 2007 5:27 pm    Post subject: Re: Need help on elevator Reply with quote
A big thank you to all of you who replied. What a wealth of information on this list!
I actually went out and bought a Dremel kit as Tom Henderson was the first to suggest. Any excuse to buy a new tool is a good excuse I guess.
It worked great. FYI: All the other cut-outs (for rudder, trim tab and trim servo inspection hole) now come ready made from ZAC which I think is great.
Thanks again,
Hans
