spray painting
dan(at)azshowersolutions.
PostPosted: Wed May 16, 2007 5:04 am    Post subject: spray painting Reply with quote
I'm getting ready to primer my elevator trim tab and was curious if anyone had found a way to paint over a piano hinge without gooping it up? Any tricks in anyone's bag?
Dan B
Mesa, AZ / Kitfox-IV
www.azshowersolutions.com/Kitfox1.html
kitfoxmike
PostPosted: Wed May 16, 2007 5:51 am    Post subject: Re: spray painting Reply with quote
vaseline
PostPosted: Wed May 16, 2007 3:22 pm    Post subject: spray painting Reply with quote
Float Flyr
PostPosted: Wed May 16, 2007 3:57 pm    Post subject: spray painting Reply with quote
Just a guess but I'd consider taking the hinge apart (remove the pin), lubricate or soap the inside of the hinge and then paint it separately. When the paint is dry it should be easy to remove from the lubricated surfaces yet should hold to the untreated surfaces. Then re-assemble the hinge. I have seen helicopters used in wildlife counting, where they actually paint caribou, pre sprayed with WD40 before each flight so the overspray is easy to wipe off. Given enough warm water the WD40 disappears too.
[img]cid:291065023(at)16052007-3240[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  270 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Guy Buchanan
PostPosted: Sat May 19, 2007 9:21 am    Post subject: spray painting Reply with quote
I did absolutely nothing preventative and it worked fine. I painted
both halves separately, took moderate care to not spray inside, and
it re-assembled and worked great.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Sat May 19, 2007 3:13 pm    Post subject: spray painting Reply with quote
