wayne.e(at)grandecom.net Guest
Posted: Tue May 15, 2007 3:55 am Post subject: First flight fuel load |
I'm at the stage where I should be leaving terra firma before to long and in Vans first flight write up they indicate not to take a full tank of fuel on the first flight. Is that what you flying people did? I guess I can see some logic in that but I will be filling the tank to calibrate my fuel level in my engine monitoring system and would then need to off load the extra fuel. I'm wavering back and forth on whether this is really necessary or not.
Anyone have any thoughts on this?
Wayne Edgerton # 40336
getting close
carl.froehlich(at)cox.net Guest
Posted: Tue May 15, 2007 4:21 am Post subject: First flight fuel load |
Half tanks reduce weight, but still more than enough fuel for first flight even if you have a problem shifting tanks.
For tank calibration, you do one side at a time. Fill the first tank one gallon at a time and record the level indication. Do this until the tank is full. Now is the time to do the fuel flow test. Disconnect the fuel line at the carb/throttle body and direct the fuel into the 5 gal gas cans. Put a cheap auto filter in line with the hose to the 5 gal can to filter out any junk that may be there. If not already done, you should bypass the airplane fuel filter/gascolator the first couple of times so that you flush the tank junk into the temporary auto filter. Using this process you verify you have adequate fuel flow for flight, and you now know the unusable fuel left in the tank (since you know how much you put in, and measured how much you pump out).
Repeat the process on the other tank. When done, split the fuel between both tanks.
Carl Froehlich
RV-8A (325 hrs)
RV-10 (wings)
[quote] --
Randy(at)abros.com Guest
Posted: Tue May 15, 2007 7:27 am Post subject: First flight fuel load |
I filled it up before my first flight because it was easier to calibrate the fuel when the tanks are empty. I was going off of a long strip, KUAO and came in at 75 kts and let the speed bleed off. No issues. I did have 100 lbs in the baggage compartment to help minimize the forward CG and that worked perfect. I would pull 25lbs at a time out until after about 10 hours I had 25 lbs in there. Randy 40006
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Tuesday, May 15, 2007 4:54 AM
Subject: First flight fuel load
getting close
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
billderou(at)yahoo.com Guest
Posted: Tue May 15, 2007 8:08 am Post subject: First flight fuel load |
Before my first flight I needed a weight and balance, needed to calibrate the fuel tanks, and needed to run taxi tests. All of these require fuel to be accurate. More or less fuel will not affect takeoff performance with one soul on board. Put some weight in the baggage compartment (50 lb) but tie it down since your aft baggage panel may not be installed. Make sure when you push the nose down trim button the elevator tab moves up. Set the elevator tab to 3/8" below the elevator trailing edge for takeoff. Assume on liftoff that the elevator trim may be too sensitive so let it climb a bit until you "test" the elevator trim. Also expect the standard Vans throttle control will back out unless it is locked.
I'll guarantee quite a rush. Enjoy. Life doesn't get any better!
Bill DeRouchey
WTD Aviation Technology
N939SB, post rush
bill(at)wtdaviationtechnology.com (bill(at)wtdaviationtechnology.com)
Randy DeBauw <Randy(at)abros.com> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } I filled it up before my first flight because it was easier to calibrate the fuel when the tanks are empty. I was going off of a long strip, KUAO and came in at 75 kts and let the speed bleed off. No issues. I did have 100 lbs in the baggage compartment to help minimize the forward CG and that worked perfect. I would pull 25lbs at a time out until after about 10 hours I had 25 lbs in there. Randy 40006
From: <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
getting close
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01[quote][b]
Posted: Tue May 15, 2007 9:35 am Post subject: First flight fuel load |
You can go either way. Full fuel with just one person isn’t a big deal for weight. You probably wouldn’t even be able to measure a performance difference between full tanks and half tanks. It may make a small difference in CG, although it is so close to the CL that it is probably also no measurable. As others suggested, I would put some weight aft to help with CG during initial testing. You will want to test with full tanks and pilot plus “copilot” for forward CG and then empty tanks with all seats and baggage full (use sandbags or boxes or books or something like that for simulating passengers) during your fly-off period. The main concern with having full tanks for the first flight would be in case you have to make an off-field landing. You want as little fuel as possible any time this may happen, but the highest chance of having this happen would be on first flight because the engine has no history on that plane. So, if you don’t mind the hastle of unscrewing the sump valve to drain the tanks after calibrating them, I would say that it wouldn’t hurt to go with half tanks, but going with full (or almost full) tanks shouldn’t be a big deal.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Tuesday, May 15, 2007 7:54 AM
getting close
[quote] [b]
kdbelue(at)charter.net Guest
Posted: Tue May 15, 2007 1:46 pm Post subject: First flight fuel load |
I'm not certain what was meant by:
"Put some weight in the baggage compartment (50 lb) but tie it down since your aft baggage panel may not be installed."
so I thought I should mention that on the 2 place planes, Van's says not to fly without the baggage panel installed because it is required to make the plane airworthy. I haven't seen anything about this on the RV-10, but would suspect that it is required also. No flame intended, just want to be safe.
Kevin Belue
RV-6A >700 hrs
RV-10 finish kit
dav1111(at)suddenlink.net Guest
Posted: Wed May 16, 2007 1:45 am Post subject: First flight fuel load |
I only put 10 gallons in each tank for the first flight. After that I filed the right tank full and during flight testing at altitude ran the left tank empty and then calibrated the left tank to calibrate.
The logic behind minimum fuel on the first flight is if there is a forced landing on the first flight you really don't want to have full gas tanks.
Russ Daves
N710RV - first flight 7/28/06
Posted: Wed May 16, 2007 3:33 am Post subject: First flight fuel load |
I've heard the same thing that the baggage panel is a structural item and should always be on for flight?
Wayne Edgerton #40336
Time: 02:46:21 PM PST US From: "Kevin Belue" <kdbelue(at)charter.net (kdbelue(at)charter.net)> Subject: Re: First flight fuel load
Kevin Belue
RV-6A >700 hrs
RV-10 finish kit
