KenWHyde(at)aol.com Guest
Posted: Fri May 18, 2007 4:53 am Post subject: Aux Hyd Pump |
Anyone know who does the overhaul on the P-366-1 Aux Hyd Pump (64650) for the 500S???
Ken Hyde
N47AC
See what's free at AOL.com.
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
kamala(at)msn.com Guest
Posted: Fri May 18, 2007 6:04 am Post subject: Aux Hyd Pump |
kh, there are two in tulsa, ok. i will get names and numbers. mason
kamala(at)MSN.COM Guest
Posted: Fri May 18, 2007 6:13 am Post subject: Aux Hyd Pump |
kh, try mid continent airmotive 405-354-6632 or jet services 800-765-0665.
mason
bowing74(at)earthlink.net Guest
Posted: Fri May 18, 2007 2:57 pm Post subject: Aux Hyd Pump |
These guys did my Pesco. http://www.aircraftaccessoriesofok.com
bilbo
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of KenWHyde(at)aol.com
Sent: Friday, May 18, 2007 8:53 AM
Subject: Aux Hyd Pump
Ken Hyde
N47AC
| Quote: | | http://www.matronics.com/Navigator?Commander-List | 01234
Posted: Sat May 19, 2007 4:21 am Post subject: Aux Hyd Pump |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> kh, they also did one for me mason
Posted: Sat May 19, 2007 7:13 am Post subject: Aux Hyd Pump |
You do need to specify “overhaul” or “repair”. They are different.
bilbo
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of MASON CHEVAILLIER
Sent: Saturday, May 19, 2007 8:21 AM
Subject: Re: Aux Hyd Pump
Posted: Sat May 19, 2007 4:09 pm Post subject: Aux Hyd Pump |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> bb,overhaul mason
Posted: Sun May 20, 2007 4:36 pm Post subject: Aux Hyd Pump |
Thanks Guys, I appreciate the help.
Ken Hyde
Posted: Sun May 20, 2007 4:40 pm Post subject: Aux Hyd Pump |
Thanks Mason
Ken Hyde
dfalik(at)sbcglobal.net Guest
Posted: Sun May 20, 2007 5:08 pm Post subject: Aux Hyd Pump |
I have two old hyd. Pumps of the P-366-1(64650) variety that were taken off and replaced with Pesco’s. These never seem to last “long” before needing overhaul/repair due to leaks. It seems that every year (app. 300 hrs.) they need some type of attention. Is this normal or just my misfortune?
Should I have the old ones (mfr. Date of 1965) overhauled and put on a shelf? The plane is a 1970 500S.
Don
barry.collman(at)air-brit Guest
Posted: Mon May 21, 2007 3:43 am Post subject: Aux Hyd Pump |
Hi All,
I haven't seen any other comments about this posting, but this is literally about the 50th time I've received it.
Anyone else had the same "problem"?
Best Regards,
Barry
CloudCraft(at)aol.com Guest
Posted: Mon May 21, 2007 5:47 am Post subject: Aux Hyd Pump |
In a message dated 21-May-07 04:45:49 Pacific Daylight Time, barry.collman(at)air-britain.co.uk writes:
| Quote: | I haven't seen any other comments about this posting, but this is literally about the 50th time I've received it.
Sir Barry,
Since you bring it up ... I was wondering if it's the pump that's leaking, or is it the Garlock seal where the pump attaches?
In my experience, it was always the seal that leaked and that was due to low aircraft utilization and the seal drying, or, the seal being damaged during installation.
If the pump is leaking, where does it leak?
Wing Commander Gordon
