		ogdenk
				 Posted: Tue May 15, 2007 4:46 am    Post subject: Strobe on vertical stab |
				 	  | Quote: | 	 		  | Hi all,I am a new builder, and am making progress on the vertical stab.  Just wonderingwhat people are doing for strobes on their RV-10's.  I am used to having a strobeon the tail of the Warrior I fly, but some of the 10's I've seen pictures of don'thave one there, and I'm pretty sure most are being built to be IFR capable.I just figured it would be easier to run wiring before final assembly of the VS.Thanks for any info, or links to pictures to see what others have done. Kent Ogden (in sunny Syracuse NY)#40710  (N710RX reserved) |
		Tim Olson
				 Posted: Tue May 15, 2007 5:06 am    Post subject: Strobe on vertical stab |
				Kent, I wouldn't discourage you from running wires that you may want to
 use later, or from lighting your plane up well for anti-collision, but..
 What is being most common on the -10s is a combination tail light/strobe
 on the rear, and then strobes on each wingtip.  That meets the legal
 requirements for daytime/nighttime anti-collision lights.  Then you
 just need to add a pair of wingtip Nav's for nighttime operation and
 you've got all the lighting you need other than any landing/taxi
 lighting you prefer.
 Kent Ogden wrote:
  	  | Quote: | 	 		   *Hi all,*
  *I am a new builder, and am making progress on the vertical stab.  Just wondering*
  *what people are doing for strobes on their RV-10's.  I am used to having a strobe*
  *on the tail of the Warrior I fly, but some of the 10's I've seen pictures of don't*
  *have one there, and I'm pretty sure most are being built to be IFR capable.*
  *I just figured it would be easier to run wiring before final assembly of the VS.*
  *Thanks for any info, or links to pictures to see what others have done.*
  *Kent Ogden (in sunny Syracuse NY)*
  *#40710  (N710RX reserved)*
		Albert Gardner
				 Posted: Tue May 15, 2007 5:23 am    Post subject: Strobe on vertical stab |
				The typical location on RV’s is a combination light/strobe at the bottom of the rudder.
 Albert Gardner
 Yuma, AZ
 40-422
 N991RV Reserved
  _________________ RV-9A N872RV
RV-10 N991RV |
