VHMUM(at)bigpond.com Guest
Posted: Sat May 12, 2007 2:13 am Post subject: dimpling tip ribs |
Anyone got an idea for dimpling the wing skins where th tips atach aprt from grinding down the No 6 dimple dies??
regards Chris
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Sat May 12, 2007 4:13 am Post subject: Re: dimpling tip ribs |
Take the time and grind the dies. I carefully ground my set and have been able to use them for the rest of the plane. This will not be the also set if die and sets you will need to modify, the fuselage will have a number of riveting and dimpling spots which require modified tools.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
Deems Davis
Posted: Mon May 14, 2007 7:59 am Post subject: dimpling tip ribs |
Nope, That's what I did.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
The McGough Family wrote:
| Quote: | Anyone got an idea for dimpling the wing skins where th tips atach
regards Chris
