rafael(at)gforcecable.com Guest
Posted: Sat May 12, 2007 12:11 pm Post subject: Initial biuld decisions |
First of all, I thank all who provided me with input in making the decision between a 9A and 7A. I have decided to build the 7A. It has not been an easy decision. Basically the balance tilted towards the 7 after considering the Vne and the added performance with the 360 engine.
Now I would like help with a couple of other decisions. First, IO-360 vs O-360. I was leaning heavily towards the injected engine, carburetor heat being the issue. However, after attending an EAA meeting this morning and talking to an RV-8 builder with a beautiful 8A with an O-360, I’m no longer sure. What advantages does the fuel injection have? Performance? Reliability? Ease of installation? Maintenance? Any other? I believe cost and weight penalty are close for either engine.
The other decision is between Constant Speed and Fixed Pitch prop. It is my understanding that the CS will provided better takeoff and climb figures and marginally better cruise performance. I’m wondering if this performance is worth the extra $6500 or so for the CS. I’m leaning towards the FP implementation, but I would like to hear comments.
Thanks and best regards to all,
Rafael
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
frank.hinde(at)hp.com Guest
Posted: Sat May 12, 2007 12:32 pm Post subject: Initial biuld decisions |
FI is more efficient and shows up most when running lean of peak (LOP). this can be a saving in the order of 1.5GPH at cruise. Carb heat is the big one, not really required on the FI but Vans does have a rudimentry warm air system...Just in case.
FP vs CS...depends on if the extra 300FPM its worth it to ya....Resale value is higher of course with a CS...and there is the "cool" factor... .. I belive stopping distances are improved with the CS as well.
Frank
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Rafael
Sent: Saturday, May 12, 2007 1:11 PM
To: rv9-list(at)matronics.com; rv7-list(at)matronics.com
Subject: RV7-List: Initial biuld decisions
Rafael
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List
mtaylo17(at)msn.com Guest
Posted: Sat May 12, 2007 2:13 pm Post subject: Initial biuld decisions |
I went with a constant speed prop for my IOF-360. It's great for descents too as you don't have to worry about overspeeding your engine. Just push the nose forward and go for it! When you throttle back with a constant speed prop, it's like putting the brakes on which is also nice coming into the pattern at warp factor 7. Just before you enter, throttle back and you'll be at pattern speed before you know it. Mine's a three blade MT BTW. It's not as fast in cruise.
Mark
www.4sierratango.com
[quote] From: rafael(at)gforcecable.com
Subject: Initial biuld decisions
Date: Sat, 12 May 2007 16:10:32 -0400
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass EC_a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass EC_span.EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Rafael
fstringham
Posted: Sat May 12, 2007 3:00 pm Post subject: Initial biuld decisions |
Rafeal
When I started my project (Sept 2004) I wasn't sure what I wanted. But as
the project unfolded I decided (very slowly) to turn a Van's
quick/light/simple flyer into a mega buck high speed/leading edge
technically/very costly RV7A......ECI Titan IO360/cold air
induction/FI/EI/ALL GLASS-Electric Panel/WhirlWind 200RV CS prop/custom
interior.................$$$$$$$$$$$$$$$$. I just coundn't
resist...........Now if I build another RV It is going to be built
simple/light weight/night VFR/less costly......
I know those that are flying can give better stats on the difference in the
all important velocity factor between a simple and complex
craft.....but....I believe one would get as much utiliy out of a less costly
simple plane as compared to the 777 that some of us are trying to build.
Good Luck in your build/decided on your mission/and have fun!!!!
Frank (at) SGU RV7A 'NDY"
| Quote: | From: "Rafael" <rafael(at)gforcecable.com>
Reply-To: rv7-list(at)matronics.com
To: <rv9-list(at)matronics.com>, <rv7-list(at)matronics.com>
considering
talking to an RV-8 builder with a beautiful 8A with an O-360, I'm no longer
cost
my
and
marginally better cruise performance. I'm wondering if this performance is
worth the extra $6500 or so for the CS. I'm leaning towards the FP
Rafael
Catch suspicious messages before you open them—with Windows Live Hotmail.
matronics(at)cencula.com Guest
Posted: Sun May 13, 2007 6:52 am Post subject: Initial biuld decisions |
I've been wondering some of the same things as Rafael, but would like to add
one more question:
When selecting an engine, does the choice of fixed pitch vs CS have any
bearing on choosing Dynafocal I vs. Dynafocal II?
I read a posting on this list that indicated Dynafocal II was intended for CS
props. The argument was that the center of mass is further forward on a CS
installation, so the focus of the mounts is further forward to match that and
reduce vibration.
Is this actually true? I've been able to find no other info to back this up,
although I have found quite a few people flying Dynafocal I motors with CS
props (which would seem to contradict the posting).
The posting is here in case anyone wants to read it:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=5148244?KEYS=dynafocal_&_engine_&_code?LISTNAME=RV?HITNUMBER=8?SERIAL=07422721769?SHOWBUTTONS=YES
Mike Cencula
On Saturday May 12 2007 04:10 pm, Rafael wrote:
| Quote: | First of all, I thank all who provided me with input in making the decision
and marginally better cruise performance. I'm wondering if this
performance is worth the extra $6500 or so for the CS. I'm leaning towards
Rafael
sportypilot(at)stx.rr.com Guest
Posted: Sun May 13, 2007 8:14 am Post subject: Initial biuld decisions |
Dynafocal I is the standard engine case type where the engine connects
To the engine mount, conical is the older style engine cases and they
Can be converted to dynafocal I for about 400.00 at places like ECI,
Dynafocal II was an oddball engine type done on a few factory type
Aircraft, these choices have nothing to do with CS or fixed pitch
Crankshafts, those differences are only if the crankshaft has a
Hollow end on the crankshaft.. Vans sells all three mounts,but they
Will Make you sign a not return form for the conical or Dynafocal II
Engine mounts.. I would stick with the dynafocal I mount and you still
Can buy an engine that has the hollow crankshaft and use a fixed pitch
Prop (it takes plugs in the end of the crank) and later you can move
Up to constant speed prop when you can afford it.. having options is
A good thing.. these items are in the preview plans.. if you have them
Danny..
add
one more question:
CS
and
reduce vibration.
up,
=YES
Mike Cencula
decision
| Quote: | between a 9A and 7A. I have decided to build the 7A. It has not been an
longer
| Quote: | sure. What advantages does the fuel injection have? Performance?
figures
| Quote: | and marginally better cruise performance. I'm wondering if this
towards
| Quote: | the FP implementation, but I would like to hear comments.
Rafael
cnpeters
Joined: 24 Aug 2006 Posts: 23 Location: Bloomington/Normal, IL
Posted: Sun May 13, 2007 8:04 pm Post subject: Initial biuld decisions |
I posted this on the RV-9 list as you posted your query there, too.
Rafael,
A couple things:
1) Regarding Vne and the O-360, it shouldn't be a big deal with the
RV-9. There are quite a few O-360 powered -9's out there, and you won't
flirt with Vne in cruise. The only time it would be an issue is in a
dive/descent, a small part of your time flying. One will need to watch
for Vne with both the O-360 or O-320 in a descent - the former will make
it a bit easier to get close in a more shallow descent. Just throttle
back, that's it. The attention to this is no different than other
critical areas of flight, such as the landing.
2) Between the O- and IO-360, there are many threads on this in the
archives for the various forums. Weight will be a non issue. The
injected models main advantage IMHO is to run lean of peak and achieve 1
gph improvement in fuel burn. A more balanced fuel mixture to each
cylinder is possible. You don't have to worry about carb icing. But,
there is some complexity, higher fuel line pressures, need for a return
fuel line to a tank and more expensive fuel selector, more difficult hot
starts. There are others on these forums that have much more real world
info since I'm still a builder.
3) FP vs CS prop - this is one of the the top three debates that rage
amongst the OBAM market (along with to prime or not, slider vs tip-up,
etc). I'm still deciding on that one, and have a year still to worry.
Frankly, I'm leaning toward an FP - lighter weight, MUCH cheaper, less
maintenance/overhaul issues. Craig Catto builds a beautiful 3 blade prop
that I have flown behind in a -9 - smooth, excellent craftmanship, and
costs $1800. He (and other manufacturers) can set you up with a prop
that is coarse pitched that will give you Van's cruise numbers.
Comparing performance numbers from various builders shows cruise numbers
about equal between a properly configured cruise FP vs a CS. You will
sacrifice climb rate/takeoff distance a bit, so if you fly into hot and
high or short fields all the time, then you need to re-think this. But
honestly, I do all my flying in Illinois and elsewhere into airports
with at least 3500' strips - really look at Van's T/O and landing
numbers with a FP prop in the -9. There are few places where you can't
go that a CS will make a difference. On the flip side a CS resell may be
better, especially with the -7. Acro and formation flying have some
benefit with a CS. One thing against the FP is slowing down and descent
rate. Coming into the pattern and trying to slow down takes a little
more forethought and earlier energy management with the FP, since the CS
can give a little drag when in fine pitch and help out. This is
particularly so with the -9. Basically, I think the argument is a little
silly, as some practice will make you competent. I fly a Dakota with a
CS, but have no trouble when I grab the glider-like Diamond DA-20 with
FP after practicing with it a little once or twice. So, for me, I'll
likely go with the FP and use the $5000 saved over the CS for about 1500
gal of avgas. That's quite a few cross-country trips!
Carl
_________________ Carl Peters
RV-9A wings |
John Brunke
Posted: Mon May 14, 2007 5:56 am Post subject: Initial biuld decisions |
Dear Carl,
In your well written response you wrote:
| Quote: | there is some complexity, higher fuel line pressures, need for a return
starts.
In my search for engines that started at Sun and Fun, I specifically asked
the fuel
return question to most of the engine sales people. Aerosport and
Mattituck both
said a return line is not needed in their fuel injection systems. I can't
remember
the response of the other engine groups, but reducing complexity is probably
better for sales.
I always assumed one would be required also. That eliminates some of the
complexity issue and relief for
me since I had already sealed up my tanks.
That also means a less expensive fuel selector, so that might bring the
injection
system somewhat closer in price to the carb system.
As for the hot start issue that could be a problem. Lycoming is now
selling non certified engines and
Jon ( the project manager, sorry I can't remember his last name), showed me
a return loop that ties into
the fuel line between the tank and the electric fuel pump. You run that
for a few seconds and it cycles
colder fuel foward of the firewall. That should solve the hot start issue.
That adds complexity and
on the fuel injected airplane I owned at one time, I would just open the oil
filler door after landing and
that seemed to work well to cool things down.
During one quick fuel stop we landed, pulled up to the pumps, the FBO filled
her up, we paid, and got right out of there. It started right up and it had
been shut down for no more
than 15 minutes. And that was in the middle of summer. OAT around 85 F.
Sincerely,
John Brunke
Posted: Mon May 14, 2007 8:01 am Post subject: Initial biuld decisions |
You could easily add an Airflow Performance "dump valve" to just about
any FI system. This simply needs a return to either tank.
It is only used to purge the hot fuel from firewall forward doing a hot
start. It works, adds very little complexity and does not require any
change to the standard selector valve.
Frank
cnpeters
Posted: Tue May 15, 2007 7:03 pm Post subject: Initial biuld decisions |
Good to know on the fuel return issue not being mandatory with some
makers - thanks for the correction. And no expensive Andair valve. There
was a thread in VAF about FI hot starts and all the tips from flyers did
point to being not too great an issue even without a dump or return
line. To blur things further, there are those with carb engines that do
run LOP - Pete Howell just posted on the RV-9-list about doing this with
an engine monitor.
RV-9A wings |
Posted: Thu May 17, 2007 5:45 pm Post subject: Initial biuld decisions |
Michael D. Cencula wrote:
one more question:
reduce vibration.
Mike Cencula
snipped
Dyna II was created for certain twins using extended hub props. I called
Van's tech help a couple of months ago, trying to determine if I could
order my finish kit without a specific engine selected. One thing they
told me was that the type II mount is no longer available due to
non-existent demand. You might want to verify that directly with Van's.
Charlie
(anybody with a mid-time x-360x they want to part with?)
