CBarber(at)TexasAttorney. Guest
Posted: Tue May 08, 2007 5:27 pm Post subject: Switch confusion |
Maybe I read it and now am forgetting (and now can't find it), but on the Z-14 drawings the two contactor switches that are called out are three position switches. Why? What are the middle positions suppossed to be used for? What position should be used during flight? I got my Z-14 layout cranking my engine today (my 46th birthday <g> ) and I was tickled to have my Wankle rotary churning over effortlessly (just cranking, not yet ready for starting). However, in my use, swithing the switches all the way up seemed to be what activated the contactors allowing the cranking. Insight to what may be obvious is appreciated. TIA.
All the best,
Chris
Peter H
Posted: Tue May 08, 2007 8:06 pm Post subject: Switch confusion |
Chris off topic . Which Wankel are you using. I ran the Norton 95HP rotary for 3 years.
Peter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Christopher Barber
Sent: Wednesday, 9 May 2007 11:26 AM
Subject: Switch confusion
All the best,
Chris
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234
nuckollsr(at)cox.net Guest
Posted: Wed May 09, 2007 7:12 am Post subject: Switch confusion |
At 08:26 PM 5/8/2007 -0500, you wrote:
| Quote: | Maybe I read it and now am forgetting (and now can't find it), but on the
A Back in the "good 'ol days" when airplanes were getting their first
generators, batteries
and a few lights, the battery master and generator control switches could
be and were separate
switches. This is because a generator will start and run by itself whether
or not a battery was on
line to go with it. When alternators came along, they needed (and still do
need) a battery to get
them to come up reliably. Further, alternators do not run well without a
battery on line. None the
less, it was desirable to have some degree of independent control of the
battery and alternator
insofar as system performance requirements would permit. This is when the
split-rocker master
switch was conceived. This switch has acquired almost magical attributes .
. . I've seen the
red-rocker enshrined in prominent locations on the panels of many
homebuilts even when all
other switches were a different style.
A little study of the split rocker shows us that the battery can be on by
itself, but the
alternator cannot. The same functionality is provided by our DP3T, on-on-on
toggle switch
(S700-2-10). Lower position is ALL OFF, mid position is BAT ONLY, upper
position is
BAT+ALT. It's true that you could replace the S700-2-10 with an S700-2-3
and turn on BOTH
devices with a single throw of the DC master switch. It's a rare in-flight
condition that the
alternator NEEDS to be off. If you're doing some battery-only ground
maintenance, then you
could pull the breaker. We recommend the S700-2-10 as an alternative to the
split-rocker
switch to provide equivalent functionality. The three positions offer ALL
OFF, BATTERY
ONLY, and BATTERY + ALTERNATOR functionality while making sure that the
alternator is
not allowed to be ON when the battery is OFF - I.e. emulation of the split
rocker
switch.
Posted: Wed May 09, 2007 2:24 pm Post subject: Switch confusion |
A Mazda second gen 13b (89 - 91) turbo core (not currently turboed though).
Posted: Wed May 09, 2007 2:39 pm Post subject: Switch confusion |
Thanks Bob, that makes sense.
We look forward to you being down here in October. Of course, I will have
made my mistakes by then <g>.
All the best,
Chris Barber, President
EAA Houston; Chapter 12
plevyakh
Posted: Wed Sep 26, 2012 6:02 am Post subject: Re: Switch confusion (S700-2-10 or S700-2-3) |
Folks,
In studying the various Z Architecture diagrams, I notice in some cases the S700-2-3 switch is used and in others the S700-2-10 is used. I understand the functionality differences.
Can anyone tell me if there are operational reasons for using an S700-2-10 switch over the S700-2-3 switch? Or vice versa?
S700-2-3 = OFF / BATT + ALT ON
S700-2-10 = OFF / BATT ON / BATT + ALT ON
Right now I have the S700-2-3 switch in my design with the ALT FLD 5A breaker to . I have a B&C L60amp primary alternator, with LR3C-14 Voltage regulator. I also have the SD-8 amp as my backup alternator.
Howard
generators, batteries and a few lights, the battery master and generator control switches could be and were separate switches. This is because a generator will start and run by itself whether or not a battery was on
need) a battery to get them to come up reliably. Further, alternators do not run well without a battery on line. None the less, it was desirable to have some degree of independent control of the battery and alternator
split-rocker master switch was conceived. This switch has acquired almost magical attributes.
. . I've seen the red-rocker enshrined in prominent locations on the panels of many homebuilts even when all other switches were a different style.
itself, but the alternator cannot. The same functionality is provided by our DP3T, on-on-on toggle switch (S700-2-10). Lower position is ALL OFF, mid position is BAT ONLY, upper position is BAT+ALT. It's true that you could replace the S700-2-10 with an S700-2-3 and turn on BOTH devices with a single throw of the DC master switch. It's a rare in-flight condition that the
alternator NEEDS to be off. If you're doing some battery-only ground maintenance, then you could pull the breaker. We recommend the S700-2-10 as an alternative to the split-rocker switch to provide equivalent functionality. The three positions offer ALL OFF, BATTERY ONLY, and BATTERY + ALTERNATOR functionality while making sure that the alternator is not allowed to be ON when the battery is OFF - I.e. emulation of the split rocker
switch.
Bob . . . |
_________________ Howard Plevyak
GlaStar / Cincinnati, Ohio |
Posted: Wed Sep 26, 2012 11:26 am Post subject: Switch confusion |
At 09:02 AM 9/26/2012, you wrote:
Folks,
2-10 is progressive transfer that emulates the split-rocker
functionality. If you use 2-3 switch, then alternator
and battery come on and off together, alternator can only
be turned off by pulling the field breaker.
Either works.
