seipel(at)seznam.cz Guest
Posted: Mon May 07, 2007 1:44 pm Post subject: RV10-List:14" Spinner - was James Cowling |
Anyone looked at the UHS fiberglass spinners that Aircraft Spruce
sells? http://www.aircraftspruce.com/catalog/appages/uhs.php
Looks like they have a 14" spinner. Don't know if it would work, but at
$174 it might be worth a try.
PJ
RV-10 #40032
evmeg(at)snowcrest.net wrote:
Really!....I had no idea! thanks for the heads up on that one....Goes to
show you that the rule holds true about deviatiating from the plans...
small change=BIG price difference. There must be a reasonable solution to
this one. Seems too simple to me.
Evan
> I'm interested in the James Cowl. I sent a note to them however about the
> 14" spinner required with this cowl. The Hartzell spinner, at $1400, cost
> more than the cowl itself. I asked them if they could do a Van's like 14"
> fiberglass spinner kit to replace the ridiculously overpriced Hartzell
> spinner. They said no.
> Carl Froehlich
> RV-8A (320 hrs)
> RV-10 (wings)
rv10(at)sinkrate.com Guest
Posted: Mon May 07, 2007 3:25 pm Post subject: RV10-List:14" Spinner - was James Cowling |
I contacted them a while back to inquire about using it with the hartzell
that Van's sells and they said it would not work. The hartzell uses a back
plate aft of the propeller and their 14" spinner is designed to with a
mounting plate in front of the propeller.
-Ben
Posted: Tue May 08, 2007 2:08 pm Post subject: RV10-List:14" Spinner - was James Cowling |
Thanks for the info Ben. If anyone hears of an option better than the
$1700 that Hartzell wants, I'd sure love to hear about it.
PJ Seipel
RV-10 #40032
-Ben
Deems Davis
Posted: Tue May 08, 2007 2:39 pm Post subject: RV10-List:14" Spinner - was James Cowling |
Aero Composites offers a 14" spinner. For $1000. I'm not sure if it will
fit a prop other than their's. The one I have spinner backplate is
machined for mounting studs that are integral to their prop hub. Give
them a call and find out for sure.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
PJ Seipel wrote:
PJ Seipel
