Garmin 496 - XM Antenna connector
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aviation-List
larry(at)ncproto.com
PostPosted: Mon May 07, 2007 2:21 pm    Post subject: Garmin 496 - XM Antenna connector Reply with quote
Installing a Garmin 496 in my Super Decathlon and the 90 degree connector for the XM Antenna has interference issues. The connector looks like a standard Mini-USB-B 5-Pin ; so I cut the cable expecting to splice on a cut cable from a standard Mini-USB-B cable.
The XM Antenna cable is 5-conductor. I’m learning that every Mini-USB-B cable I buy and cut is 4-conductor. Does anyone have any good answers ?? All I’m needing is a straight connector on my XM Antenna.
Larry E. James
Bellevue, WA
Super Decathlon
Rocket (under construction)
- The Matronics Aviation-List Email Forum -
http://www.matronics.com/Navigator?Aviation-List
reichec
PostPosted: Mon May 07, 2007 2:49 pm    Post subject: Garmin 496 - XM Antenna connector Reply with quote
If you are wanting it to fit in that panel dock thing, you should have carved the plastic out that it interferes with. You may be SOL and have to buy a new antenna/reciever.
PostPosted: Tue May 08, 2007 7:39 am    Post subject: Garmin 496 - XM Antenna connector Reply with quote
Hi Charles,
I am not using the AirGiamo mount – it wastes far too much height and its quality doesn’t meet my standard. I have designed and built my own mounting and the interference of this USB connector is with the Garmin SL40 that resides right below the 496. My question and predicament remain. Does anyone know if all 5 wires in the Garmin GXM30A antenna are used ??? So far even Garmin has been no help.
Larry E. James
Bellevue, WA
Super Decathlon
reichec
PostPosted: Tue May 08, 2007 3:38 pm    Post subject: Garmin 496 - XM Antenna connector Reply with quote
Pending the level of your own adventuresome spirit, you can disassemble the puck antenna and trace down if all the wires are used if my memory serves me right. I was trying to figure out how to take the magnet out of one of the older style puck reciever/antennas.
Charles
Rhino
PostPosted: Mon Aug 06, 2007 11:43 am    Post subject: Re: Garmin 496 - XM Antenna connector Reply with quote
Assuming you are using the GXM 30A Smart Antenna, it uses a male right angle USB 2.0 5 conductor Mini-B connector. If you want such a connector without the right angle, just about any 5 conductor Mini-B cable would give you one. Try this search:
http://www.google.com/search?hl=en&q=male+mini-b+connector
Rhino
PostPosted: Mon Aug 06, 2007 11:55 am    Post subject: Re: Garmin 496 - XM Antenna connector Reply with quote
This might work:
http://www.aircraftspruce.com/catalog/avpages/airgizmosAntCable.php
It's meant for the Airgizmo, but it's just a cable, and it's straight.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aviation-List All times are GMT - 8 Hours
