		dlm46007(at)cox.net Guest
				 Posted: Sun May 06, 2007 10:19 am    Post subject: Flying RV10 tire wear |
				For flying 10s how is the tire wear? If you could supply indicated tire wear
 and total time/approx. number of landings between tire changes it would be
 helpful. When building my Glastar we followed the book procedure for toe in
 and it caused toe in of 3 degrees per wheel which caused significant uneven
 tire wear. We were able to fix this by rotating the gear legs slightly and
 up sizing the gear retainer bolt. I know that the toe in on the 10 is a
 given but it can be changed if the tires are wearing rapidly. That's the
 reason for the question. Anyone with significant wear can email me off line
 and supply a phone number to talk.
		mritter509(at)msn.com Guest
				 Posted: Sun May 06, 2007 11:31 am    Post subject: Flying RV10 tire wear |
				I have 92 hours on my RV-10 and 87 landings over the last nine months.
 Slight wear on outboard side of mains.  Will rotate them this summer and
 hopefully get another 100+ hours before replacing them.
 Mark
 N410MR
  	  | Quote: | 	 		  From: "David McNeill" <dlm46007(at)cox.net>
 Subject: Flying RV10 tire wear
 Date: Sun, 6 May 2007 11:11:29 -0700
 wear
 Get a FREE Web site, company branded e-mail and more from Microsoft Office
		Tim Olson
				 Posted: Sun May 06, 2007 3:33 pm    Post subject: Flying RV10 tire wear |
				Mine had wear on the outer sides, but not to the cords and PLENTY of
 tread depth to the rest of the tire, that was at 170 hours and about
 200 landings.  Flipped them over and there is no noticeable wear
 happening to the previously worn, previously outer edges, and it'll
 take a long time again to get the *new* outer edges wearing out.
 I'm estimating another 100-125 hours left on this set of tires
 before I replace them.  I had intended to just use them through
 the winter when I'd have ice patches on the runway, but right now
 I'm thinking I may as well leave the new tires shrink wrapped
 and just keep going with these for their lifetime.
 Mark Ritter wrote:
  Mark
  N410MR
 > To: <rv10-list(at)matronics.com>
 > tire wear
 > would be
 > toe in
 > uneven
 > and
 > line
		bob.kaufmann(at)cox.net Guest
				 Posted: Sun May 06, 2007 4:51 pm    Post subject: Flying RV10 tire wear |
				I have 300 hours and 375 landings on tires and am about to switch them to
 get wear on the other sides.
 Bob K
 All of those hours and landings are in my mind of course.
 91/09 and counting
		dav1111(at)suddenlink.net Guest
				 Posted: Mon May 07, 2007 3:08 am    Post subject: Flying RV10 tire wear |
				All of Bob K.'s 300 hours 375 landings are NOT in his  mind.  Only about 295/365.  Unlike a lot of builders Bob K. has actual  RV-10 stick time, including a cross country from Vegas to El Paso  and flying a 3 ship formation with two other RV-10's.  How  soon one forgets!!!
  Russ Daves
  N710RV - First Flight 7/28/06
  Original Message:
       Bob  K
       Do not  archive
       91/09 and  counting
		Randy(at)abros.com Guest
				 Posted: Mon May 07, 2007 6:39 am    Post subject: Flying RV10 tire wear |
				In 180 hours I have almost 0 tire wear. Build it per plans and you will
 be fine.  Randy 40006
		Rick S.
