Bottom Rudder Bracket attachment
chris Sinfield
PostPosted: Sat May 05, 2007 9:28 pm    Post subject: Bottom Rudder Bracket attachment Reply with quote
Hi Gang
I am using the latest plans 03/06 and have a Q. On page 6-B-2 bottom LH coner , it shows a lower rudder hinge. Ths hing USED to have 2 3/16" bolts 2 A5 rivets and a tiedown bolt on it with a row of 4 X A5 rivets behind. (older plans) on my plans it shows the rivets next to the tiedown bolt as being replaced bu 2 more 3/16" bolts , but the top RH corner of that Hinge picture still shows 6 X A5 with only 4 ++++.
Should there be 6 A5 rivets in the back row or 4??? is the 6 a mistake? as the 2 A5 rivets in the next row are now bolts??
Chris
Down Under..
Jaybannist(at)cs.com
PostPosted: Sun May 06, 2007 6:07 am    Post subject: Bottom Rudder Bracket attachment Reply with quote
Chris,
My plans (dated 08/05) show the 4 AN3-5A bolts plus the tie-down ring in the aft row and 4 + marks for rivets in the forward row; but a note that says "six rivets A5", pointing to the forward row. I just looked at mine and I have 6 rivets.
Somewhere in the Zenith documents, they tell you NOT to count + marks for rivets and to go with what is called out. I guess this is an example of what they were talking about.
Jay in Dallas
"chris Sinfield" <chris_sinfield(at)yahoo.com.au> wrote:
Hi Gang
Chris
Down Under..
http://forums.matronics.com/viewtopic.php?p=111113#111113
wa7dvd
PostPosted: Sun May 06, 2007 2:54 pm    Post subject: Re: Bottom Rudder Bracket attachment Reply with quote
I think the reference to 6 A5 rivets is a carry over from earlier sets of plans. I have three versions and it is there in the all three. I believe it is counting 2 in one row (now replaced with AN-3 bolts) and 4 in the other row. The construction photos in the guide clearly show four rivets in the second row of the finished aircraft.
I hope in only needs four on the back row because that is how mine is built.
BK Johnson
N601BK (reserved)
chris Sinfield
PostPosted: Fri May 11, 2007 1:35 pm    Post subject: Re: Bottom Rudder Bracket attachment on XL Reply with quote
Hi Gang
Got up in the middle of the night down here and rang Zenith about the wording of the 6 holes. Yes it is a mistake on the plans and there should only be 4 rivet holes in the second row behind the tiedown point.
The 6 will be replaced with 4 on the next plans update.
Chris
Down Under..
planecrazydld(at)yahoo.co
PostPosted: Fri May 11, 2007 3:04 pm    Post subject: Bottom Rudder Bracket attachment Reply with quote
MHerder
PostPosted: Sat Feb 23, 2008 10:59 am    Post subject: Re: Bottom Rudder Bracket attachment Reply with quote
OK so assuming that the prints are incorrect on the number of A5 rivets it says 6, someone has confirmed with Zenith that the correct # is 4, is the number of bolts still 4 as indicated in the drawings? Two are shown in the manual.... Yes, I understand the drawings take priority over the manual and not to count the x's for rivets. Anybody mind taking a look at their QB kit? How is Zenith installing them these days?
Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying
craig(at)craigandjean.com
PostPosted: Sat Feb 23, 2008 11:23 am    Post subject: Bottom Rudder Bracket attachment Reply with quote
Take a look at these shots of my QBK.
-- Craig
 Filesize:  30.91 KB
 Viewed:  751 Time(s)
 Filesize:  38.34 KB
 Viewed:  762 Time(s)
 Filesize:  34.47 KB
 Viewed:  797 Time(s)
 Filesize:  31.45 KB
 Viewed:  821 Time(s)
MHerder
PostPosted: Mon Feb 25, 2008 6:22 am    Post subject: Re: Bottom Rudder Bracket attachment Reply with quote
Thank you Chris, I appreciate your time spent taking your pictures.
I have been building for a few months now, everyone I've come across has been so helpful. I appreciate all of you out there who are willing to take some time to help others out. I wonder what it would be like if I wasn't building a Zenith? Without so many helpful folks I would still have a pile of aluminum in my garage. Now I have a pile of aluminum that is beginning to resemble a plane! I had a question that I wrote to Zenith the other day, Sebastian replied via email in less than 30 minutes! I couldn't believe it.
Though I am new to the list, I look forward to offering my experience and advice as I progress. At this point I only feel qualified to instruct others on the techniques of drilling out and replacing rivets Smile .
Zodiac 601 HD
Jabiru 3300
Finally Flying
